Engine stalling (KOEO code 14)
Old Feb 2, 2018 | 03:29 PM
Epicduck's Avatar
Epicduck
​​​​​​I have a 91 ford f150 with a 5.0. Been trying to fix a stalling issue for a while now and every time I think it's fixed it starts having problems again. The only consistent thing is the code 14. We have replaced the distributor, tfi, coil, cap and rotor, and ignition switch. I have cleaned all the grounds i could get to under the hood and checked for power and good connection on all the ignition wiring. Please help I'm out of ideas.
Old Feb 2, 2018 | 03:37 PM
rla2005's Avatar
rla2005
New rebuilt distributor?
Code 14 is a stored code. Did you clear the codes after replacing the distributor? If not, you have no idea when that code was triggered.
Old Feb 2, 2018 | 04:12 PM
Epicduck's Avatar
Epicduck
Rla2005
I reset the code after replacing each part.
Old Feb 2, 2018 | 04:18 PM
joey2fords's Avatar
joey2fords
you are in good hands with RLA, but he may or may not not be up to speed with your weird issue of stalling when the blower motor is turned off ... thus, it's best to stick to one thread for the same problem.
Old Feb 2, 2018 | 05:10 PM
rla2005's Avatar
rla2005
Oh....that one. That is very strange. I would suspect a missing body or PCM ground.
Bill (Subford) has some good info for where the grounds are on bricknose trucks. My documentation goes back to 1992 and I have learned the previous generation trucks tend to be very different.
I can point to where they are on a 1992 and up. But, I do not want to lead you astray. Given some time I may be able to find some old threads where Bill replied.
Old Feb 3, 2018 | 11:42 AM
F350 1990's Avatar
F350 1990
I hate to say this, but aftermarket parts (e.g. distributor / pickup) can provide those very intermittents you're experiencing. Could be totally unrelated to that code too - the 91's computer isn't that 'smart"
Do you happen to remember were base timing was set? Any "add on" electronics (e.g. CBs, radios, etc)?
Old Feb 3, 2018 | 12:00 PM
Epicduck's Avatar
Epicduck
The time I do not remember where it was set and the only add on at the time was a new radio. More has been added since. But there was a time when we would change out the horn or put on some fog lights or add whatever that the truck would go from running good to acting up. But after a while I kinda just blew that off as coincidence.
Old Feb 3, 2018 | 12:18 PM
88n94's Avatar
88n94
So Epicduck, explain to us what the truck is doing now? Do you still have to have have the heater fan on for the engine to run? When the engine quits, how long before it will restart?
Old Feb 3, 2018 | 12:50 PM
Epicduck's Avatar
Epicduck
Right now it is running fine I can turn everything off and on with no problems. So kinda afraid to mess with it right now especially with rain coming. Restarting can be from a day to four days. Seams like it may have a little to do with the weather.
Epicduck
2015 + Expedition & Navigator
Feb 5, 2018 11:35 AM
Kyle Campbell
Feb 11, 2016 12:42 PM
itsafordguy20
Jul 26, 2008 09:49 AM
RTM
Jan 12, 2004 06:54 AM
Sundevil Brett
1983 - 2012 Ranger & B-Series
Dec 5, 2003 07:06 PM
