Sponsored by: Real Truck
Another door chime problem
Old Jun 5, 2025 | 06:23 PM
inlinescott's Avatar
inlinescott
Trailering
My door open chime goes off even with no key in ignition. I have removed the black and pink wired contact from the ignition tumbler and the chime still goes off when the door is open. The contact has continuity to ground (when removed). I trace the black and pink wire into a harness. Can someone help me find the next point to check?
Old Jun 6, 2025 | 08:01 AM
WWR's Avatar
WWR
Is it thinking your headlights are on?
Old Jun 6, 2025 | 08:17 AM
inlinescott
Trailering
Good point, lights were definitely off but I should check that one too. It stops chime when the door is closed (or latch is thrown) and I thought lights on chime would go off even with door shut. A few questions:
Is it correct that the black and pink wire to the ignition tumbler is a ground?
Where is the next point to check the "door open, key in" chime?
Where would I look to check/disconnect the "lights on" chime?
Thanks for any help on this
Old Jun 6, 2025 | 09:16 AM
WWR's Avatar
WWR
I'm not sure on the wiring but our '07 F150, '08 F150 and '11 SuperDuty only do the headlight chime with key off and door open
Old Jun 6, 2025 | 09:25 PM
inlinescott
Trailering
Disconnected both batteries to charge. One has drained to many times and won't take charge so now must be replaced. Fiddled with the tumbler a bit and when I connect one of the batteries no chime for a couple minutes. Turn to start then back off and still good so I think I got it. Then it starts to ding again next time I open the door. Disconnected for a few minutes, reconnect wait a minute or two and starts again. Longer I disconnect the longer before it starts to ding. Any ideas?
Old Jun 8, 2025 | 02:04 PM
LexxiStarr's Avatar
LexxiStarr
4wd Low
Door Chime
You know it funny you mention this i have opposite issue where since a aftermarket Remote start was installed Chime doesnt work and Horn beeping to confirm truck is locked doesnt activate
R&T Babich
Feb 1, 2019 07:08 PM
P7M8
Electrical Systems/Wiring
Sep 22, 2012 05:26 PM
superduty4x4
18
May 16, 2011 10:18 AM
kevinshin
1983 - 2012 Ranger & B-Series
36
May 8, 2004 04:01 PM
streadway
1997 - 2003 F150
Sep 15, 2003 09:53 PM
