Door ajar chime
Old Sep 22, 2012 | 02:42 PM
P7M8's Avatar
P7M8
Door ajar chime
I have read a dozen + forums and "answers" on this question, none have worked. Apparently '99's & '01's are a bit different in the wiring.
I have a 2001 F350 CC XLT. I have already did the bit with the ignition and disconnecting the brass contact. That has solved my key chime.
I want the door chime to stop when the key is in acc. position when the driver door is open.
Any help please.
Old Sep 22, 2012 | 05:26 PM
Franklin2's Avatar
Franklin2
Close the door or disconnect the door switch inside the door. This stuff is programmed inside the modules on this newer stuff, so you are stuck on some of it.
hyperbot13
Electrical Systems/Wiring
Aug 15, 2018 09:06 AM
sgrol
6.7L Power Stroke Diesel
May 12, 2014 02:40 PM
Streetcruzer
Apr 14, 2009 09:09 AM
trakman
Apr 25, 2005 11:54 AM
Alex G
1983 - 2012 Ranger & B-Series
Jan 13, 2003 09:27 PM
