Suggestions for towing
to all the suggestions
nothing beats education
Read, re search
Make sure trailer is ready for long haul
There aRe countless lists all over
even one made rv manufacturers
of course safety is paramount
Have a safe journey
Also a point on the built in "sway control". It's passive and only fully kicks in once sway starts. it can also interfere with an active sway control system and fight it, causing brakes to get hot. IOW I would not fully rely on it with something like an RV. On any other trailer though, you are right a WDH is not required.
I stand by my comment that a properly designed and loaded trailer (travel trailer or not) should not have sway issues AND that not every tow vehicle requires either a weight distribution hitch OR any additional sway control measures. With my 176" wheelbase, heavy diesel truck and dual rear wheels along with my well designed and balanced ORV trailer (which is a very small load for my truck) I neither benefit from using a WD hitch, nor do I require any additional sway control. I've towed with this setup from Canada to Arizona and back in every possible weather and road condition possible and I'm 100% convinced. That said and as I previously mentioned my setup is, while not unique, certainly overkill as far as the TV is concerned......many, perhaps even most, RV trailer/truck combos would benefit from both WD and additional sway control.You're right about the factory sway control being reactive; it hasn't ever engaged on my truck.....a testament to not having any sway issues.
Cheers,
Dave
Since I have never used a scale like this before. How is it done? Do you weigh the pickup with the added payload and then weigh the trailer (including items for camping, etc)?
Once you get the results then what?
2. (If not using a weight distribution hitch, skip this step) Unhook the tension bars of the weight distribution hitch and get the same weights.
3. Park the trailer somewhere and get the front and rear axle weights of the truck alone, with no trailer hooked up.
From those numbers, you can get the true tongue weight of the trailer and the amount of weight restored to the truck's front axle by the weight distribution hitch. You can also calculate the percentage of your trailer's tongue weight.
Simple example to proof it. You got the truck loaded, the RV loaded and hitched up. You got the WDH setup perfectly. Now you just put a 130 pound genny and 70 pound cooler at the tailgate. Is your WDH still setup correctly? No, because you just added 200 pounds to it.
you added 200 lbs of Payload to the bed of the truck, not on the hitch itself (even if it's right at the tailgate
) and it's proper or improper loading will possibly affect the height of the ball (not likely 200lbs will make a difference if added to a 1 ton at the last minute). Your WDH should still be configured correctly for your trailer & it's payloadSince I have never used a scale like this before. How is it done? Do you weigh the pickup with the added payload and then weigh the trailer (including items for camping, etc)?
The scale will have at least 3 scale pads, the forward one will be for the steer axle, the second is for the drive axle and the third is for the trailer axles. Try to spot your tires on the center-ish of the pads and stay away from the edges.
CAT now has an app for use of their scales, which I have not used yet. I still use the original method of pulling into the scales and then pressing the call button for the scale operator inside the store. When they answer I tell them I’m a private party weigh and give them a reference name like “Tom’s RV”, they will reply that they have your weight. Then pull off the scales and circle around to the rear of the line, if there is one. If no others are waiting to use the scale you could quickly release the tension on your WD hitch and then request your second set of weights. After the operator says they have that weight then drive off and Park in the truck lot to drop your trailer, the proceed back onto the scales for your truck only weights. After all three sets of weights are finished you can go into the store to pay and get your weight slips, the whole process should take less than 30 minutes (if there is no other traffic over the scales) and cost you about $20.
If you have any questions about the scale results once you get them stop back in here to ask and we can help explain what the various weights actually show and how to calculate the exact tongue weight and amount of weight being transferred by the WD hitch.
