Suggestions for towing
I prefer using a good hard bolt as the connector between the two halves. I don't think that is preferred by most but the standard way is just a pain to deal with whether using a block and a hammer or a C-clamp.
have fun.
Dave
Reese has hundreds of videos and data on wd hitch of its required or a strong suggestion etc
as well as curt, husky etc
WD is generally recommended if towed trailer weighs more than half the weight of the towing vehicle
my truck weighs 8900 lbs
So anything over 4450 lbs
WD, transfers some weight to the steering axle
which is important, it also reduces the see saw motion from roads , humps. Uneven pavement etc. Just because we can toss 3k lbs in the bed, or are rated up to 1200 lbs dead weight at receiver , does not negate skipping on gearb to make your drive comfortable and safe
sway control is a huge safety and driving benefit for longer trailers.
tongue weight is important
As is level pull
Education is key
Read, watch videos etc
Weigh your vehicle, weigh the trailer, set hitch weight correctly
Lights.
And enjoy
remember the stuff in the bed also counts against the tongue weight..in so much as squat and level
As is level pull
Education is key
Lights.
And enjoy
"The load in the bed is part of the total weight the truck is carrying (payload), and the tongue weight of a trailer is also part of that total. You need to ensure that the combined weight of everything in the truck, including the tongue weight, does not exceed the truck's payload capacity"
Further Reading
As is level pull
Education is key
Lights.
And enjoy
- 1) the "half of the weight of the tow vehicle" is a generalization that makes more sense with light duty tow vehicles rather than an F350 (see Class 8 tractor trailer trucks for eg.)
- 2) a properly designed and loaded trailer will not have sway issues regardless of whether or not you use a WD hitch or some other form of sway control
- 3) The primary function of a WD hitch is to restore weight to the front axle and/or remove weight from the rear axle.......depending on the actual specs on your truck and trailer, this may or may not be desired.
- 4) there are downsides to WD hitches that many people are unaware of or gloss over - you can reduce weight on the drive axle to the point you could lose traction on low friction surfaces and induce a jack-knife. In circumstances where there is a fair bit of attitude difference between the truck and trailer (at the base of a steep driveway for eg.) or you hit a frost heave at speed you can damage your trailer's A frame to the point of failure.
- 5) there are other means of sway control other than using a WD hitch; stand alone friction sway control devices or electronic sway control (Ford SD's come with electronic sway control)
I have 8 trucks and 9 trailers and we tow daily. I have had and still have several WD hitch setups and I'll use them if the circumstances warrant one. With my F350 DRW diesel, 4x4, CC, 176" WB truck towing my Outdoors RV 25RDS I have no need of a WD hitch and don't use one......I haven't for 3 years now including a trip from Canada to Arizona and back in all kinds of conditions, weather, wind and speeds. I'm very happy with the stability of my set up. Lastly a WD hitch can dampen "porpoising" but I used a GenY Torsion Hitch to accomplish that. The OP may or may not benefit using a WD hitch depending on the actual specs on his truck and the actual weight, size and design of the trailer.
2 cents,
Dave
2 cents,
Dave
Also a point on the built in "sway control". It's passive and only fully kicks in once sway starts. it can also interfere with an active sway control system and fight it, causing brakes to get hot. IOW I would not fully rely on it with something like an RV. On any other trailer though, you are right a WDH is not required.
Further Reading
Simple example to proof it. You got the truck loaded, the RV loaded and hitched up. You got the WDH setup perfectly. Now you just put a 130 pound genny and 70 pound cooler at the tailgate. Is your WDH still setup correctly? No, because you just added 200 pounds to it.
2 cents,
Dave
Last edited by krisk01; Jun 20, 2025 at 07:23 AM. Reason: Displaying symbols incorrectly
With an equipment trailer, you can adjust your load back and forth, side to side, etc to get to the desired tongue weight and getting your sway down to almost zero.
With an RV, the vast majority of your weight is fixed and static. You can't really move slides, cabinets, the fridge, stove, etc. They're put where they are and unless you disassemble the entire inside of the trailer that weight is what it is. As you load things (bedding, clothes, food, other supplies) you'll more than likely make the tongue weight only go up, because a lot of storage for that, especially in travel trailers, is up front. Depending on water/waste tank locations you MIGHT be able to add water behind the axles to lower tongue weight but it's unlikely to be enough...and unless you FILL the tank, now you have a 'live load' situation that can slosh around and potentially make sway WORSE.
Then you have toy haulers, which are even worse, really. They are notoriously nose-heavy because they've basically crammed the entire RV portion in front of the axles (give or take) and left the rear empty. Now yes, loading up the rear CAN make the tongue lighter, but even then you've got to be careful - they're usually only rated for a payload of 2-3k lbs for some reason. That usually STILL leaves them very nose-heavy, and there's very little you can do about it.
This is why I hold that a great many people who pull 35' RVs with their half-ton trucks are under-trucked, and that most of them who say it 'pulled like a dream' have either gotten REALLY lucky with the layout of their camper, are just inexperienced as to what that tow would feel like with a truck the right size, or are just lying to themselves so they can justify their decision to be under-trucked.
to all the suggestions
nothing beats education
Read, re search
Make sure trailer is ready for long haul
There aRe countless lists all over
even one made rv manufacturers
of course safety is paramount
Have a safe journey
