1978 - 1996 Big Bronco
Left front grind.
Old Dec 5, 2003 | 09:19 PM
CaptMike's Avatar
CaptMike
Left front grind.
I was going to plow today and when I put the truck in 4 wheel drive (autolock hubs) the left front wheel started grinding.
Sounded like metal on metal disk brakes, but the brakes are good.
Any ideas? I need the truck to plow tomorrow and need a place to start and an idea of what to look for.
Thanks
Old Dec 5, 2003 | 09:36 PM
AbadDriver's Avatar
AbadDriver
I got the samw rubs that your talknig about so in kinda curious to what it is.
Tim
Old Dec 5, 2003 | 09:42 PM
90ebbronc's Avatar
90ebbronc
My 90 did that as well. Capt. Mike does it do it when the shifter is in 2 wheel drive. Mine did it when in two wheel drive and i had to have the hubs replaced, so i went to manual. The auto hubs that were on my bronco wouldnt disengage, or fully engage, was stuck in between. It made a bad metal to metal grinding noise, almost like it was about to fall off.
Old Dec 5, 2003 | 09:47 PM
CaptMike's Avatar
CaptMike
In 2 wheel drive the truck is fine. No noise at all.
4 wheel sounds like the thing is tearing itself apart.
Old Dec 5, 2003 | 10:05 PM
DW2455's Avatar
DW2455
have you checked the ujoints? just a idea. good luck
DW
Old Dec 6, 2003 | 07:17 AM
AbadDriver's Avatar
AbadDriver
Mine has new new ujoint. less than 2 months old. Any other Ideas?
Tim
Old Dec 6, 2003 | 10:07 AM
DW2455's Avatar
DW2455
if its not the brakes, wheel bearing, or u-joint, then may be it the auto locking hubs? DW
Old Dec 7, 2003 | 01:28 PM
AbadDriver's Avatar
AbadDriver
warn hubs here. could it be something actually in the ttb arm thats not aligned(greased) properly?
Old Dec 7, 2003 | 05:55 PM
90ebbronc's Avatar
90ebbronc
Ok not to sound stupid, but i just had this happen to me. I had this metal to metal grinding noise coming from the front left as well. Then finally i hit something and it was the same sound. Not to sound like a smarta'' but it was my center piece on my wheel. The screws were loose and needed tightening, it stopped the grinding noise. Might wanna check that as well, it fooled me so it could be it.
Old Dec 7, 2003 | 08:36 PM
AbadDriver's Avatar
AbadDriver
do any of you think it could be the c-ring left off when the hubs were changed over?
Tim
Old Dec 7, 2003 | 10:44 PM
screwy's Avatar
screwy
Did you install the new C-ring that should have come with the kit?
Old Dec 8, 2003 | 09:20 PM
AbadDriver's Avatar
AbadDriver
it didnt have a c-ring in the kit so i left it out. when i finished i had no spare parts so i felt like i did it right. guess not.
Tim
Old Dec 8, 2003 | 10:45 PM
swenson's Avatar
swenson
Do you have the Warn Premiums? I just had a set installed when i was having the balljoints and front axle unis installed on my Bronco, and when I put it in 4wd this weekend when it snowed I got the same front-left grinding. I could actually feel it catch each time I shifted from forward to reverse. It was fully locked, I even unlocked/locked it a few times to see if something wasn't catching. Maybe Warn made a bad batch of hubs or something? I know I'm going to have mine checked out in the next couple weeks, the guy who installed them said he warrantied his work for life.
Old Dec 9, 2003 | 01:49 PM
AbadDriver's Avatar
AbadDriver
mine are just regulr warns. im gonna tear into it soon and see if i can figure it out.
tim
Old Dec 9, 2003 | 02:02 PM
BillyBob69's Avatar
BillyBob69
OK... Yes! YOU NEED THE C-RING! Thats what hold the hub mechanism in place. Without it in there, when you turn you hubs to lock them in, they wont turn in far enough to engage completely and will cause the grind. If you dont have it, go get it.
Try NAPA, or Autozone. Will only cost about a dollar. Now, if you do have all the rings and parts in, make sure there isn't alot of grease in the hub assembly. There isnt alot of friction in there. You only need the grease in the bearing area. If there is too much grease around the hub assembly, and being the return spring in there isnt all that strong to begin with, the grease can and will keep the hub from going in and fully engaging. If you need assistance as to the parts that should be in there...go here and enter your truck info. they will have pics.
