No electrical power
Old May 31, 2025 | 09:42 AM
aidenkraeger17's Avatar
aidenkraeger17
8th Gear
No electrical power
Hello all,
I just bought my first obs, and it’s already been quite the headache. The batteries were 10 years old and only started on jump. Went ahead and replaced both and she ran good for a couple of days. Then I opened the interior fuse box… and every fuse was replaced with a 30amp? Got them all switched out to their proper size and now the truck doesn’t even have lights. Key in ignition no gauge cluster lights, head lights, cigarette lighter. Nothing. And obviously wont even turn over. So, I replaced all of the fuses with the old 30amps that was in it and still nothing. I’m at such a loss with this thing. I’m not sure what changed overnight? All I did besides the batteries and fuses is clean the cold air intake and attempt to remove the gauge cluster bezel. Any help is greatly appreciated!
1996 F350 7.3, Partial XLT conversion from last guy
Old May 31, 2025 | 11:02 AM
Jimmy's Pilot Service's Avatar
Veteran: Navy
First...
DO NOT EVER...NEVER.... OVER FUSE A CIRCUIT.....
You will burn your truck to the ground.
Do you get the WTS? Nothing will happen without the WTS.
Get FORScan and the OBD adapter they tell you to use. You should have an OBD II under the steering wheel area to the right, if OBD I it is under the hood. Learn to use it.
Do the attached PDF... not quite correct for your truck but close enough.
File Type: pdf
Old Jun 2, 2025 | 12:03 PM
knottyrope's Avatar
knottyrope
Clean your battery posts and try again.
Do you have charged batteries?
Old Jun 2, 2025 | 02:53 PM
Hit Man X's Avatar
Hit Man X
What are you on? The OBD2 port on these is not under the driver's steering wheel. Forscan does not work with any OBD1 I have seen either.
PO of OP's truck did all the incorrect fuses.
Agree with Knotty, start there. Post pics of your batt terminals.
Colton horn
May 11, 2025 03:45 PM
SleeprLegend
Sep 16, 2012 08:32 PM
beefy t
Oct 25, 2010 07:32 PM
robs01f250
Apr 3, 2008 11:39 AM
Douglas DC-9
May 31, 2006 06:19 AM
