oil leak
Old May 30, 2025 | 09:22 PM
natedahlquist's Avatar
natedahlquist
5th Gear
oil leak
let me begin by saying truck has 48,000 miles. i noticed some oil leaking from up above i sprayed the whole underside and after driving and checking i noticed the plug from the bell housing was leaking oil? unless it was coming down from somewhere else? if this plug is leaking what is the leak?
[img alt="let me begin by saying truck has 48,000 miles. i noticed some oil leaking from up above i sprayed the whole underside and after driving and checking i noticed the plug from the bell housing was leaking oil? unless it was coming down from somewhere else? if this plug is leaking what is the leak?
"]https://cimg6.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/2000x1504/img_5220_7c27a897d332f4b402885e460453abebef96da73. jpeg[/img]
Old May 31, 2025 | 12:04 PM
Maxium4x4's Avatar
Maxium4x4
What year is the truck Nate?
Old May 31, 2025 | 04:13 PM
natedahlquist
5th Gear
it is a 2007
Old May 31, 2025 | 05:42 PM
bismic's Avatar
bismic
It is coming from somewhere else:
https://www.ford-trucks.com/forums/8...att66f100.html
Old May 31, 2025 | 09:36 PM
natedahlquist
5th Gear
Originally Posted by bismic
i have factory cracked hot side cac boots i can see oil coming from the angle one right off the turbo dripping down into valley.. i’m going to fix that and clean out the valley and see how she goes. i just bought the truck all original 07 harley edition with no miles so i want to keep it 99.9%😣 thank you!!
Old Jun 1, 2025 | 06:14 AM
bismic's Avatar
bismic
The silicone boots from Riff Raff Diesel last a long time. They hold up very well to the oil in the intake air system from the CCV.
https://www.riffraffdiesel.com/inter...c-boots-03-07/
Old Jun 1, 2025 | 10:19 AM
Maxium4x4's Avatar
Maxium4x4
Sounds good, process of elimination.
Old Jun 2, 2025 | 01:47 PM
FiveOJester's Avatar
FiveOJester
Just so you know the 6.0's are notorious for leaking oil from all kinds of places. It usually ends up on the bell-housing of the trans. Mine had a leaking cam sensor (o-ring was nicked) and the crank sensor still leaks (too much hassle) along with I'm pretty sure the bedplate seeps as well. At least with it dripping from the same spot on the bellhousing its easy to put a catch pan under it?
A new one I found recently, I had not torqued the intake manifold properly on a previous repair and was getting oil coming out of the driver-side intake gaskets, all over the oil cooler cover. That was making the nice "hot oil" smell after long drives. Seems to be better now that the intake is torqued properly.
Old Jun 2, 2025 | 03:52 PM
natedahlquist
5th Gear
i’ve had a few 6.0’s in the past all of witch leaked oil and it didn’t bother me as bad and this isn’t my daily driver.. just to where it’s leaking and the truck has 46k original miles and is 100% flawless it does bug me😂 i know they hold about 15 quarts of oil so it may or may not show on the stick between oil changes but where i’ll be taking it on vacation for a decent drive in july im just going to overthink the fact its leaking oil haha🤷🏼‍♂️
natedahlquist
May 30, 2025 09:18 PM
bbsitum
1997 - 2003 F150
Jul 8, 2021 09:28 AM
badluck b
16
Jan 4, 2013 07:00 AM
BillyBob69
Jul 1, 2012 12:04 PM
ewstrand
Bronco II
Aug 15, 2007 06:54 AM
