Codes after cam phaser replacement
Old May 29, 2025 | 07:29 PM
DirtyFerd's Avatar
DirtyFerd
I've just changed my phasers and chains on my 2017 3.5l and now it has a bunch of codes that won't clear. I've checked and double checked all my connections and pretty sure they're all good. There are a lot of them. I don't have a scanner or Forscan, just a code reader. The truck seems to be running great, I'm just hoping somebody can point my in the right direction to solving this
Old May 30, 2025 | 05:59 PM
DirtyFerd's Avatar
DirtyFerd
Well after driving the truck for a bit, most of the codes have cleared but there are still four showing for the pcv system
Old May 31, 2025 | 08:28 AM
SMSTX's Avatar
SMSTX
Double check all the nipples on your CAC tube and your hose clamps on your throttle body. Make sure the connectors are actually locked in
Old May 31, 2025 | 10:02 AM
B+ squad's Avatar
B+ squad
Old Jun 3, 2025 | 06:03 PM
DirtyFerd's Avatar
DirtyFerd
Originally Posted by B+ squad
Do you have anything aftermarket installed? A catch can, CAI?
Nothing aftermarket.
Old Jun 4, 2025 | 10:54 PM
Bluegrass 7's Avatar
Bluegrass 7
You have only 3 codes.
1. 2237 two times is open Ox Sensor 1-1 control lead.
2. 51D two times. Crank case pressure Sensor, lead open.
3. 0401 Invalid speed signal from the PCM.
Likely damage from doing the work.
Look at the wiring below the PCM connectors on the passenger side.
Open or faulty circuits won't just go away.
Good luck.
CoryLee
2023+ Super Duty
Jan 15, 2024 04:50 PM
roboford
May 4, 2021 08:24 PM
Painter27
2004 - 2008 F150
Nov 23, 2014 10:21 AM
sarnott140
Sep 2, 2011 07:11 PM
sgrol
Mar 24, 2009 10:47 AM
