E4OD Torque Converter Lock Up Behavior
Old May 31, 2025 | 09:21 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Originally Posted by DEK460
Hey guys, I'm hoping Mark Kovalsky sees this as I know he is the transmission guru here. My truck is a 1990 F250 with the E4OD/460.
This is more my curiosity than anything, but does the E4OD unlock the torque converter just before the shift to overdrive? I've always noticed a smaller RPM drop after the shift to overdrive, which I assume is the torque converter clutch locking up, but since it typically locks up right after it shifts to 3rd, that would indicate that it unlocked before the shift to overdrive. If this is the case, what would be the rationale for it? Would the shift to overdrive be harsher with the converter locked vs unlocked? Thank you!
It would be firmer if the converter didn't unlock for a split second between shifts, but it would probably increase the lockup clutch ware if it didn't too.
Originally Posted by seschenburg
There are really no other problems with the transmission itself.
There are no problems at all then. Your trans is working as designed.
GasGuzler
May 9, 2024 12:08 PM
Fordman96
Sep 5, 2021 11:44 AM
Prototypemech
Apr 17, 2015 12:40 AM
DWMAC
Nov 25, 2002 10:22 PM
Monsta
Jan 26, 2002 10:23 AM
