Vacum and brake bleeding problem
Old May 27, 2025 | 11:34 PM
mustang81's Avatar
mustang81
Frame off restoration to paint the frame and when i re-start the truck it run good untîl i plug the vacum advance from the distributer to the carb it die instantely.? I advance it then start again with out the timing advance plug and run fine. I plug it again and run 5 second then die. what im doing wrong ? Im a good backyard mechanic but when for fine tuning im lost. I play with the distubuter back and forth but its not working. New distributer cardone with 460 elite weight in it. I only remove the carb to pull the engine trans and case in one shot. I suspect maybe vaccum leak. The drive train was remove for 3 years. Any help wîll be apreciated
Rgd9664
Jul 31, 2012 04:21 PM
dreuter
Apr 5, 2010 07:06 PM
gthbryce
39
Aug 17, 2009 09:48 PM
swickg331
Jul 7, 2008 09:45 AM
e william
Sep 29, 2007 09:21 PM
