Another oil cooler thread
Old May 22, 2025 | 07:03 PM
syjl's Avatar
syjl
Angry Another oil cooler thread
I live in Vegas and the truck was leaking oil out of the coolant reservoir in Kansas. Classic oil cooler seals or so I thought.
Got it towed to Denver and went home to return another day.
Flew to Denver and replaced the seals. Drove it for a day around town and things looked good.
However, it made it to Grand Junction and then started leaking oil into the coolant again.
I nursed it home to Vegas and pulled the cooler again.
A dirt bike front tube clamped on each end and a pan of water shed light on the issue as this link shows Oil Cooler pressure test
My recommendation would be to always check the tube for leaks before putting the Orings (from Diesel ORings) in and wasting new oil and coolant like I did.
If I had done that, I would not have had to do this twice.
New tube on its way from Diesel Orings. sigh
Old May 23, 2025 | 09:30 AM
knottyrope's Avatar
knottyrope
Thats a tough one to go through, they usually leak oil out at the outer seal on the cooler
An internal leak usually isnt the issue with orings as they dont usually harden up like the external ones do.
Old May 23, 2025 | 09:39 AM
AppleFordParts's Avatar
AppleFordParts
SPONSOR
Just for reference, we have the OEM cooler for less and we do have it in stock. https://parts.applefordwhitebearlake...er-1c3z6a642aa
We have the o-rings too, https://parts.applefordwhitebearlake...ng-1c3z6c610ba and https://parts.applefordwhitebearlake...et-1c3z6k649ba
-Steve
__________________
spowell@appleautos.com 1-800-328-9552 dfairbanks@appleautos.com
Old May 23, 2025 | 10:38 AM
INFRNL's Avatar
INFRNL
I would say the position you were in, this would easily be overlooked...especially when traveling. Glad you made it home and were able to find the issue though. Also crazy how expensive those coolers are now.
Old May 23, 2025 | 10:59 AM
syjl's Avatar
syjl
I wish I had checked Apple Ford first. Dammit
Old May 25, 2025 | 01:41 PM
syjl's Avatar
syjl
I have a brand new oil cooler sitting here but I don't know which end goes where.
There is a different spacing of the oil baffles on the one end. Pic below
Does it matter which end goes where?
I would call diesel orings but it is Sunday of Memorial Day weekend.
Any help would be great so I can finish the job.
Thank you
Jeff
Old May 27, 2025 | 09:03 AM
AppleFordParts
SPONSOR
Did you figure it out? I don't believe it matters which direction it's installed. I even checked the service manual and there's no mention of it.
-Steve
__________________
Old May 27, 2025 | 11:17 AM
syjl's Avatar
syjl
It does not matter which end goes where.
The indentation signifies that it was made by International and is, therefore, the OEM part and not a knockoff.
White95PSD
55
May 3, 2022 02:32 PM
vtown00
21
Feb 12, 2015 08:13 PM
7.3bo-ti-etr
27
May 2, 2012 07:32 AM
HH60FE
Dec 28, 2011 12:08 PM
footer99
Mar 23, 2008 07:00 PM
