driver door sags
Old May 20, 2025 | 10:33 AM
boybowser's Avatar
boybowser
driver door sags
97 F250HD extended cab, the drivers door is sagging, I have done all I can do with the striker adjustment, looking for recommended ways to loosen the door hinge bolts to adjust the door to the cab lines.
Old May 20, 2025 | 11:07 AM
wwhite's Avatar
wwhite
Replace door hinges.
Align door by loosening door hinges.
Ways to loosen?
- using sockets, extensions, swivel joint, wrenches with flexible headss
Old May 20, 2025 | 12:16 PM
My4Fordtrucks's Avatar
My4Fordtrucks
The door is sagging because the hinges are worn out. Replace them.
Old May 20, 2025 | 02:04 PM
boybowser's Avatar
boybowser
yea the doors hinges do have a bit of play, any recommended sources for decent hinges?
Old May 20, 2025 | 04:01 PM
My4Fordtrucks
Tried to find the brand I used on the Bronco II but couldn’t find the receipt.
Old May 20, 2025 | 05:37 PM
seschenburg's Avatar
seschenburg
Could just be that the pins and bushings need to be replaced. Takes about 20 minutes to do all four.
Old May 20, 2025 | 05:48 PM
My4Fordtrucks
Could be but I’ve never had any luck only replacing the pins and on my trucks the spring that holds the door open was also broken. That is why I replace the whole hinge assembly.
Old May 20, 2025 | 06:31 PM
seschenburg
My4Fordtrucks..no argument there.
You might want to watch a few videos first to get an idea of the tools needed. There's not a lot of swing space in there with the fender in place.
Anonymous12
Paint & Bodywork
May 10, 2023 07:34 AM
primered
Mar 19, 2009 11:16 PM
ngng
Jan 2, 2009 07:57 PM
brentleedragon
Oct 24, 2008 03:30 PM
DANA60
2004 - 2008 F150
Oct 12, 2007 09:14 PM
