Sponsored by: Real Truck
Loosing engine oil
Old May 20, 2025 | 08:15 AM
mookie1's Avatar
mookie1
Trailering
Loosing engine oil
Changed engine oil and filter after coming back from a 2500 trip because having to add 4 qts of oil. I have no leaks and don’t see any smoke out the tail pipe. After the oil change it seems like I’m going through 1qt every 500 miles. Truck has 56k. Would a bad turbo blow it though the inner cooler?
Old May 20, 2025 | 09:07 AM
Pikachu's Avatar
Pikachu
What year/engine?
Old May 20, 2025 | 09:08 AM
F250_Super_4X4's Avatar
F250_Super_4X4
Thats an awful lot of oil for no leaks.
Have you looked at the Trans bell housing? Possibly a rear main seal and the oil is collecting in the bell housing?
Are you running a CCV to atmosphere or exhaust?
Old May 20, 2025 | 09:14 AM
mookie1's Avatar
mookie1
Trailering
2016 F350 6.7
no leak at rear main. No spots under where I park it. This happened on the 2500 mile trip.
Old May 20, 2025 | 09:21 AM
F250_Super_4X4
Is your engine stock? If not what upgrades have you done?
Old May 20, 2025 | 09:23 AM
speakerfritz's Avatar
speakerfritz
Is there an increase in dpf build ?
Old May 20, 2025 | 04:15 PM
mookie1's Avatar
mookie1
Trailering
Stock , dpf usage is same.
Old May 20, 2025 | 04:18 PM
mterickson's Avatar
mterickson
Any oil in the coolant?
Old May 20, 2025 | 04:51 PM
mookie1's Avatar
mookie1
Trailering
No oil in coolant.
Old May 20, 2025 | 08:37 PM
INFRNL's Avatar
INFRNL
oil mixing with fuel possibly? but you'd think it would smoke?
Old May 22, 2025 | 02:43 PM
PSI-op's Avatar
PSI-op
My first thought is it was under filled to begin with. If it’s still low after a change though maybe that’s not it. A bad turbo would blow oil into the intake tract through the intercooler. I would remove the tube from the lowest spot in the intake where it joins to the intercooler. Some oil coming out is normal, but if it is a large amount I’d say you’ve found your issue. Next thing to check is to remove the oil fill cap with the engine idling. Does is have a bunch of pressure behind it that makes it “pop” off? It should not. If it does there is either a ton of blowby from bad rings/scored piston or the CCV is plugged up. I don’t think there’s any way that oil could get mixed with fuel on a 6.7, but I could be wrong.
Old Jun 8, 2025 | 09:15 AM
mookie1's Avatar
mookie1
Trailering
Thanks for the reply’s. I’ve taken it into the dealer ( still have extended warranty) they did an oil change and are doing an oil consumption test. Every 200 miles needs to be checked at dealer.
bigbubba87
Feb 18, 2012 07:53 PM
kmprr
Oct 28, 2007 11:06 PM
Pa Builder
Sep 27, 2005 08:45 PM
92GT5ohRed
Apr 27, 2005 08:27 PM
eharman
Nov 30, 2003 08:23 PM
