400 stuck distributor
Old Dec 5, 2003 | 05:16 PM
oldcarnut's Avatar
oldcarnut
does anyone have any tricks on how to get the distributor in my 400 loose? iv'e tried all mine and it still won't come loose. thanks oldcarnut........77 super cab, transplanted 400 from a ranchero.
Old Dec 5, 2003 | 06:07 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Have you tried soaking it with PB Blaster? Will it turn at all or just not pop up out?
Old Dec 5, 2003 | 07:06 PM
oldcarnut's Avatar
oldcarnut
i haven't tried PB blaster but no, it won't even turn it's stuck tight and i need to adjust the timeing pretty bad. i hade the same problem with the 352 in my 60 t-bird and ended up breaking it
Old Dec 5, 2003 | 08:27 PM
Torque1st's Avatar
Torque1st
Posting Legend
Try a search here, this has been discussed a "few" times.
Old Dec 5, 2003 | 09:08 PM
cantedvalveFord's Avatar
cantedvalveFord
My dist. is stuck also in my 400, the best fix I heard so far is, remove the top, wrap a chain around it, and use a large auto body slide hammer to pull it out. The penetrant sometimes work but not always. The slide hammer will always work.
Being my truck runs fine as is, I'm leaving it alone for now.
Old Dec 6, 2003 | 01:17 AM
macguyver's Avatar
macguyver
If the timing is that far out, is it possible that the timing chain is on its way out?
tomwerm
Jan 28, 2015 09:19 AM
400Nut
Apr 28, 2014 11:27 AM
live2hunt
Oct 7, 2006 11:26 AM
ClatonK
Oct 16, 2005 06:47 PM
blue88EB
May 4, 2003 05:13 PM
