Random rear end chatter
Old May 18, 2025 | 06:36 PM
uuuhCharlie's Avatar
uuuhCharlie
I’m having an issue that I can only describe as a chatter at the rear end. I have not figured out a way to reliably create the issue but it’s anywhere from 35-75 and will last about 1-2 seconds go away then happen again at random times. I’ll be rotating my tires soon just cause it’s time but I don’t think that’s gonna fix it. I have no other symptoms no vibration felt in the whole truck my shifts feel fine the engine pulls strong and milage all seems the same. Pretty stumped and would appreciate any ideas you guys can offer. It is equipped with an lsd diff and the sound is definitely further back than the transmission thinking at the rear left wheel as of now.
thank you
Old May 18, 2025 | 06:50 PM
tbear853's Avatar
tbear853
I had an '85 Thunderbird and at interstate speeds, if in a right hand curve, I heard a chatter. I figured was a maybe defect or nick in the axle at the edge where the bearing rode and right hand curve just moved the axle outwards enough to where it touched the end of the rollers.
Never did get to fix it, sold the car after 23 years though.
Old May 18, 2025 | 09:45 PM
Johnny Paycheck's Avatar
Johnny Paycheck
Possibly you need a refresh of the diff fluid with some friction modifier.
Old May 19, 2025 | 07:23 PM
1saxman's Avatar
1saxman
Johnny might be right but you probably need to do this anyway. You have to change the rear oil and use the special additive more often with a factory LSD. There's another factor - if you have tires of different diameters or even different air pressures on the axle, it can heat up the clutch in the rear and use up the fluid. I had a rear wheel bearing go out on a live rear axle once but it didn't chatter - it roared.
Old May 23, 2025 | 03:09 PM
uuuhCharlie
Thanks for the reply’s! Will definitely take the advice and change at least my rear differential fluid this weekend but, I did notice this while rotating my tires this weekend. Looks like that park brake cable has been slapping between my right leaf spring and the fuel tank. I’m gonna figure out something that will work but am I missing a clipping point for this or is this just normal placement and not a likely cause of the sound.
Old May 23, 2025 | 06:56 PM
1saxman's Avatar
1saxman
You must live in the 'rust' belt.
Old May 31, 2025 | 10:47 AM
WWR's Avatar
WWR
If that's at full droop I wouldn't worry. If that's ride height it might be a concern.
ANYWAY, if your noise is when driving straight (I think you mentioned highway speeds) it's very unlikely your CrapLok is to blame. Typically limited grip clutch chatter is low speed tight turns like maneuvering a parking lot.
Old May 31, 2025 | 02:37 PM
1saxman's Avatar
1saxman
That's right.
Old May 31, 2025 | 05:49 PM
WWR's Avatar
WWR
I took a look at my '07 and the parking brake cables appear to be routed exactly the same way, so I think you're fine there.
Old May 31, 2025 | 07:52 PM
uuuhCharlie
It’s been a week since changing the fluid and have not heard a peep from the rear end and I was getting the sound at low speed just not as often. Seems like the fluid was the actual fix and I will update if something changes but we’re looking good now.
Old Jun 3, 2025 | 04:56 AM
techrep's Avatar
techrep
now grab a set of billie's for the rear...
ScarletNova
2009 - 2014 F150
May 7, 2025 04:13 AM
CraigK
May 7, 2010 01:37 PM
Sicko
16
Jan 6, 2005 07:11 PM
DWEELER
2004 - 2008 F150
Sep 9, 2004 10:57 PM
