Need Help Sheared Roll Pin
Old May 17, 2025 | 07:40 PM
Grey89F150's Avatar
Grey89F150
What size is the roll Pin and best way to replace it
Old May 18, 2025 | 05:29 AM
FuzzFace2's Avatar
FuzzFace2
Are you talking the pin for the gear to distributor shaft?
Or there is a pin for the DSII distributor that holds the star wheel on the distributor shaft up top.
Being you have the distributor out just take it to the hardware store to get the right size.
Dont over think this it cant be that hard to find the size.
Dave ----
Old May 18, 2025 | 12:59 PM
Grey89F150's Avatar
Grey89F150
Grey89F150's Avatar
Grey89F150
it's bad, I may need to replace the camshaft
Old May 18, 2025 | 07:35 PM
FuzzFace2's Avatar
FuzzFace2
It is not the roll pin that is bad but the distributor gear!
I would not worry about the pin but you need to be thinking about a motor rebuild as all that gear metal is throughout the motor and stuck in the bearings.
Also when the motor is apart for a cleaning and rebuild you should be able to find why that happened as that is not normal even if the motor has 300K+ on it.
If the pin broke the gear would look good with hardly any wear showing.
Dave ----
Old May 18, 2025 | 08:05 PM
Grey89F150's Avatar
Grey89F150
Yeah I was planning on rebuilding for awhile,
the last mileage on it was 273,000 miles about 10 years ago, i got the records on it up to that point
Old May 18, 2025 | 08:13 PM
Grey89F150's Avatar
Grey89F150
After some thinking I'm going to buy a little car and start rebuilding it
Old May 19, 2025 | 07:58 PM
FuzzFace2's Avatar
FuzzFace2
That is the smart thing to do with that many miles on it and the way that gear looks
Dave ----
Old Jun 5, 2025 | 06:54 PM
Grey89F150's Avatar
Grey89F150
I got a used block I'm going to rebuild to put in my truck
Old Jun 7, 2025 | 04:40 PM
FuzzFace2's Avatar
FuzzFace2
If it runs it might be better to drop it into the truck and use it while you rebuild the motor you pulled out?
Note the 87> blocks dont have a hole for the fuel pump. You can have it machined out when rebuilding it.
Dave ----
Old Oct 1, 2025 | 07:31 PM
Grey89F150's Avatar
Grey89F150
Well i didn't do a full rebuild. But I got it running with the factory efi.
I had to get a new Cam, lifters, Distributor and oil pump.
the oil pump had tight spots.
Roger w jr
Jun 4, 2022 11:10 AM
Andrewfriend
Dec 1, 2016 06:53 PM
maztool
Car/truck Buying Advice
Feb 10, 2007 05:43 PM
REELNAUTI4U
Jan 19, 2007 03:04 PM
skirka
Sep 3, 2006 05:10 PM
