Gear ratios
Old May 15, 2025 | 10:10 PM
Stokley26's Avatar
Stokley26
4th Gear
Gear ratios
So I had to put a new rear end in my truck and I found a good deal on a 3:31 gear ratio and installed it my front differential is a 3:55 I’ve had to use 4x4 once or twice and haven’t had any problems I’m just curious if there is any chance of damage from using 4x4 with mismatch gears
Old May 16, 2025 | 07:50 AM
Johnny Paycheck's Avatar
Johnny Paycheck
Press your luck long enough and something will bind up.
Old May 16, 2025 | 07:54 AM
Evan76's Avatar
Evan76
I would definitely not run on high traction situations.
But in all realistically worldy ****. 3.3 and 3.5 are very close to the same. I think ford used to run a faster front gear a few hundred years ago. But then trucks werent doing 90 down the freeway with the driver texting. Things are very different now.
Old May 16, 2025 | 07:57 AM
seventyseven250's Avatar
seventyseven250
If you use 4x4 in snow, mud and ice, that's close enough. Don't use it on clean dry roads, or for anything other than getting going and you are fine.
Even on slippery roads, I wouldn't want to drive in 4hi down the road, because you'll have a mismatch in "push" and it could handle a bit weird.
Old May 18, 2025 | 08:37 PM
stephen.osborne1's Avatar
stephen.osborne1
The difference was like 3.89 and 3.92... .03 difference. 3.31-3.55 is quite a bit different. I don't see this being a good combo, even off road.
Sportsman1970
Sep 10, 2022 08:10 PM
DaltJo2000
2015 - 2020 F150
19
May 13, 2021 09:20 AM
blacklab1
Jun 30, 2011 09:09 PM
polacko
32
Jun 14, 2010 08:00 AM
Joe Meg
6.7L Power Stroke Diesel
Jan 18, 2010 05:35 PM
