4x4 gear ratio front and rear
The reason they are sometimes off by a few hundredth is due to different numbers of teeth on ring and pinion gears from front to rear.
Example:
Front diff has 41 ring gear teeth, and 10 pinion gear teeth, 41/10 = 4.10 ratio
Rear diff has 37 ring gear teeth, and 9 pinion gear teeth, 37/9 = 4.11 ratio
This will work on the same rig front and back, but any more than a few hundredths difference front to rear will cause bind if you put it in 4x4 with any kind of traction
Example:
Mike Clough
01-19-2014 02:57 PM
klosterk
10-25-2005 09:01 PM
