6.7 Fuel additives
Old May 14, 2025 | 05:53 PM
fish4ever's Avatar
fish4ever
4wd High
6.7 Fuel additives
What are the best fuel additives that you use? Never was big on them until I started using them in my Optimax and seen good results (I know their apples and oranges)
I have a 2016 with 125,000 miles on it and would like to run it until 300,000 if possible. I do regular oil changes and anything to help my CP4 live longer I will try
Old May 14, 2025 | 06:16 PM
speakerfritz's Avatar
speakerfritz
There are a lot of different additives out there…some are wide scope and cover different areas like water, anti gel, cetane, lube, bio code, etc and some are targeted to one thing or the other like just certane, etc.
What I see a lot is folks using a cetane boost only and then cry when their cp4 blows up becuase they needed a lube additive and never used one.
analyze locally avail fuel and decide based on that what the fuel additive needs are…and follow thru
sone additives makes the analysis process easy
Old May 14, 2025 | 07:49 PM
fish4ever's Avatar
fish4ever
4wd High
I specifically want it to give my CP4 a "fighting chance"
Old May 14, 2025 | 07:59 PM
speakerfritz
water treatment, lube additive, biocide, anti gel
antigel for winter
water treatment always
lube additive if your local is not pumping b5 bio or better
biocide if local fuel is high on bio fuel
etc
Old May 14, 2025 | 09:37 PM
Sport45's Avatar
Sport45
I use opti-lube XL at 1/2 the recommended dosage (1oz/20gal). Just figure to boost the lubricity a bit while minimizing risk to the DPF. Makes me feel better about things but can’t say for sure it’s a winning recipe.
Old May 15, 2025 | 06:01 AM
Overkill2's Avatar
Overkill2
This conversation is like which oil/grade is best and which OCI is best... and you know what they say about opinions.
I've been using K100D since about new, truck now has 138k miles and have had the S&S DPK Gen 2 installed for about two years now for insurance.
Started using Pittsburgh Power's Max Mileage FBC about two years and now use it with their newer additive Flashpoint in a mixed 16 oz bottle of 10 oz FP/6 oz MM (per their recommendations). Still use K100D.
It appears the FP is similar to K100D but adds more cetane than K100D does, hence why I'm using. K100 adds lubricity, is a fuel cleaner, fuel stabilizer, controls water and is an anti-gel (double dose in winter). I use MM to reduce the combustion temp of soot to help out my DPF.
Yes I have OCD.
Good luck.
Old May 15, 2025 | 07:01 AM
F250_Super_4X4's Avatar
F250_Super_4X4
IMHO there are two clear choices based on third party testing (Stoking the fire a little)
If you conduct oil analysis regularly - Diesel Kleen
If you do not conduct oil analysis regularly - Opti-Lube
*** Never use an oil additive
Old May 15, 2025 | 10:39 AM
FishOnOne's Avatar
FishOnOne
So I've met your goal of running to 300,000k miles and I ran most those miles without an additive, but the diesel I mostly run has some bio additive. Having said that, I've been running Archoil for the last year and it clearly makes my engine run quitter and regens are less frequent.
Old May 15, 2025 | 12:45 PM
doczenith1's Avatar
doczenith1
I run a mix of 2/3 Summer+ and 1/3 XL and have some XPD on hand for sub zero F temperatures. This cocktail has worked well over the last 14 years and 150,000 miles. No fuel system issues.
Old May 15, 2025 | 12:57 PM
Overkill2's Avatar
Overkill2
Then there's Troy to make us all look bad... but I don't live in Texas and I use double the dose for anti-gel and for more possible water in the tank during the cold winter months from condensation.
You go Troy! Me? I'm way too OCD to not use additive... but not so much that I clip off the nubs off new tires.
As to regens, my last was about 440 miles out just from daily driving. I'd say I'm doing okay.
Old May 15, 2025 | 02:52 PM
acdii's Avatar
acdii
Been using EDT for years in all my diesels, from the 3 cylinder Kubota with Mechanical injectors, 23 years now purring nice and strong, my 2021 Kubota L4060, never misses a beat and DPF stays cleaner longer than the average, and my 6.7's. for the price per dose, its the best bang for the buck. Archoil is better in some situations but is also quite expensive and uses twice as much per dose. I tried one large bottle during the winter, saw no difference in anything compared to EDT, but going to try it again once my current EDT is used up and compare summer driving with it.
One claim of Archoil is the DPF stays cleaner longer, but saw no proof since my 24 regens like clockwork every 540 miles or so, and the filter never goes above 30%. I'll compare summer driving and DPF percentage and see if theres any improvement. I never let diesel sit long enough in the truck to worry about algae or gelling, so those additives are not on my list of must haves for the truck but I do use anti gel in my 50 gallon storage tank for the tractors.
Old May 15, 2025 | 04:00 PM
Overkill2's Avatar
Overkill2
Actually microbes, not algae, and if diesel has "bugs," it means it has water in it. Microbes need not only food (diesel), but water as well to grow in diesel fuel. Stop the water, no bugs. At least this is what I've read about bugs requiring water to grow in diesel.
https://www.hpcdfuel.com/pdf/DOWfuel_training.pdf
NIH has an article on biodiesel... huh...
https://pmc.ncbi.nlm.nih.gov/articles/PMC9018388/
Old May 15, 2025 | 04:38 PM
augam's Avatar
augam
How much snake oil could one man possibly buy in a life time?
Old May 15, 2025 | 04:39 PM
Overkill2's Avatar
Overkill2
You think water in fuel is snake oil?
Old May 15, 2025 | 04:41 PM
augam's Avatar
augam
Not an additive guy - never have been in 65 years. Drive the vehicle like it was designed to be driven.
