I have a '24 F350 LU and have wondered if the camera view order can be changed (when pressing the camera button.) The issue I have... when pressing the camera button to view the overhead view, when pulling into a parking space, etc, the side cameras showing the doors are displayed. Pressing the camera button again it goes back to the default infotainment screen. If I press the button again the side cameras are displayed. If I stop moving and press the camera button the overhead camera displays on the screen.
Searched past threads about this and found nothing. I also looked through the owners manual with no luck either.
If the side cameras view is the default view can this be changed? Trying to figure how to get the overhead camera view to show up fist when the camera button is pressed.
Any thoughts...
On my '24 F250 Lariat when I am pulling into a parking space, and I hit the camera button, my forward facing (grille) camera is the first to display on the screen. Once in that screen I can use the camera menu to select other views. I don't think the overhead view automatically shows on mine unless I have put the truck in reverse. When it's in reverse then the overhead shows up on the right side of the screen and the back-up camera shows on the left side of the screen.
I have set the back-up camera to stay on for a little longer, even when in drive, so I can still watch the rear view and overhead view.
Update: As I did an online search I discovered the camera view order can not be changed. It was set at the factory. However, still not sure why the side cameras is what shows up first (I am not pulling a trailer)?
My Platinum with proximity sensors on the front turns on the front view automatically when it sees something close in front. It's pretty handy when pulling into the garage as it sees the sidewalls first and bing, on comes the cam.
I must say, I HATE the yellow lines on the overhead view, I hated them on our 2016 F150 Plat too. I don't see the point, and they just make it harder to see curb edges when parking.
