Electronic Fuel Pump
Old May 9, 2025 | 07:25 PM
peenhead's Avatar
peenhead
I drive a '97 F250HD, 7.3L, 307K, original owner. Just finished replacing the HPOP, Adrenaline, new hoses, and a new manual fuel pump. Considering going to an electric fuel pump, any recommendations? Would it be easy to assemble the components and put the system together myself? Any suggestions are appreciated. Thanks
Old May 9, 2025 | 07:28 PM
Edgethis's Avatar
Edgethis
Lots of folks here have made their own setup. Easiest is to just use the Bosch pump the SD 7.3s came with. Super cheap and reliable.
Old May 9, 2025 | 08:19 PM
97-psd's Avatar
97-psd
There are a couple of kits available or you can build your own. I built mine, so it is not that hard if you have some simple skills. I second the Bosch pump. It is reliable and readily available.
Old May 10, 2025 | 09:05 AM
Hit Man X's Avatar
Hit Man X
I made a thread for installation of my kit. Worth a search, I think it was in '19. There are a few other solid kits available.
Currently I have a 255 Walbro, they are not Diesel rated. The Boosch 7.3 SD unit is, I THINK Aeromotive has one that is that moves a ton of fuel. Decide how much power you want, then pick a pump accordingly.
Old May 12, 2025 | 12:31 PM
knottyrope's Avatar
knottyrope
https://www.ford-trucks.com/forums/1...for-250-a.html
or can get a kit for more money
Alexis Garcia
Mar 18, 2025 04:10 AM
BRay09
Sep 22, 2015 07:19 AM
naturescape
Nov 8, 2010 07:41 PM
SamD
1947 and Older Ford Trucks
Mar 21, 2004 01:18 PM
