Offroad & 4x4
4x2 to 4x4 conversion Subscribe Q
Old May 7, 2025 | 12:13 AM
Bakky's Avatar
Bakky
8th Gear
what all would have to be changed in order to convert a 4x2 to a 4x4? and how much time would it take? instead of buying another truck to swap parts is there a kit that would do this? I want to do this but my dad is too lazy to help me, and was wondering, for the most part, if it could be a 1 man job.
87 f150 long bed 302 AOD
Old May 7, 2025 | 03:30 AM
tjc transport's Avatar
tjc transport
i ain't rite
one man job? yes. but much easier with two.
kit? not that i am aware of, but i never looked for one.
what needs change? a lot. front suspension , trans , 4X4 shifter, probably drive shaft, and other miscellaneous parts.
Old Jul 14, 2025 | 11:28 AM
MBDiagMan's Avatar
MBDiagMan
Depends on how you want to go about it and what your skills and equipment availability consist of.. Do you weld and fabricate? If so you can find a front axle and suspension system and engineer it into place, and probably have to change gear sets in one or the other front and rear so they match. Means you need to be proficient setting up a gear and pinion which is no task for even a skilled DIYer.
if all this is foreign to you, I would suggest finding a four wheel drive truck either to rob the components from or build your truck starting from there. No kit to my knowledge and if there is it will probably require the skills and equipment availability I described.
Hope this helps.
Doc
Old Apr 21, 2026 | 07:30 PM
uglyred250's Avatar
uglyred250
If the body of the truck is in good shape and worth saving and it runs and drives. I would be on the lookout for a 4x4 frame that rolls. Then body swap the frames. The cab might already have the tcase shifter location marked out already or un bolt it. But enjoy it if you can and keep looking and thinking.
FiveO
Offroad & 4x4
16
Dec 15, 2024 07:09 AM
helimd
Jul 3, 2004 08:00 PM
wycowboy
Mar 25, 2004 11:22 AM
D's 302 B2
Bronco II
Sep 14, 2003 12:55 PM
TheBigBadWolf
Sep 2, 2003 01:09 AM
