Thanks for your help.... I did find a place to buy NOS Stanadyne injectors... At the same time I'm going to take a compression test... What values should I be looking for? I get scattered information from the internet... Thanks Again...
i call anything over 300 psi compression on an IDI engine good.
if i remember correctly, new engine is 375-400 PSI.
My NA 1993 has just about 310 on all 8cyls.
I runs great and doesn't use a lot of oil.
Lights right up if I use the glowplugs.
Still wondering about the ticking lifter in the rear pass side... even after I replaced it and the rocker arm
