axle interchange
Old May 2, 2025 | 01:09 PM
Rick1025's Avatar
Rick1025
axle interchange
I have 2 E350s. one 2002, one 2004. Each one has a dana 60 semi-float rear axle. I want to put a full float in each one. Does anyone know what years interchange. I have been loking, and everyone I find is a semi float.. I have a full float from a 99. will it interchange? Thanks for any reply.
Old May 2, 2025 | 06:56 PM
BLK79's Avatar
BLK79
All I can add is I also have a 99 E350 that is full float D60. I don't see any reason it wouldn't interchange. Has the same flange as 95 and 06 E150's I've got. Driveshaft length compared to an 8.8 would probably be slightly shorter due to longer snout. Shouldn't be an issue for what you want to do.
Old May 3, 2025 | 12:42 AM
Conanski's Avatar
Conanski
Originally Posted by Rick1025
I have 2 E350s. one 2002, one 2004. Each one has a dana 60 semi-float rear axle. I want to put a full float in each one. .
Why? What are you doing that will overtax the 6k rated semi float D60? The FF version used in vans is only rated for about 500lbs more, the axles used in other trucks isn't a direct swap due to differences in spring perch locations and side axle lengths.
Old May 3, 2025 | 08:17 AM
Rick1025's Avatar
Rick1025
Spoiler
Old May 3, 2025 | 08:34 AM
Rick1025's Avatar
Rick1025
interchange
For some reason my last reply didnt post,so. Over the years I have chewed up 2 semi float rear axles.The semi float may have the weight capacity but I am not a big fan of the whole design. I prefer the large tapered bearings to the rollers. Just a preference I suppose
Old May 3, 2025 | 01:35 PM
Conanski's Avatar
Conanski
Yeah the FF is a beefier design for sure. There was a rash of faulty bearings in axles through the early 2000's, I had an 04 with an axle that howled loudly and my father had the same problem with an '04 or '06 F150. He had his rebuilt but I ran mine until the truck was scrapped and it never got any worse. 1-ton vans are where you will find a FF but they have to be standard passenger/cargo vans not a cab & chassis due to the spring perch location differences mentioned earlier.
joshofalltrades
Aug 16, 2018 07:28 PM
Rick1025
Aug 3, 2018 09:13 PM
Gettysburg150
Apr 19, 2014 08:53 PM
idaho211
Jul 20, 2008 09:00 AM
