Bubbling at spark plug
Old Apr 29, 2025 | 08:27 PM
Jack Morgan's Avatar
Jack Morgan
4wd Low
Hello,
slowly been cleaning up and fixing up an old 90 300, started her up today after replacing starter and was looking around the engine bay and found that cylinder 6 was bubbling out of the spark plug & the surrounding area is wet and caked with sludge.
I have included a video attached, any idea what the issue/fix is? Didn’t have time to play with it
File Type: mov
Old Apr 29, 2025 | 08:59 PM
Conanski's Avatar
Conanski
Cracked cylinder head.
Old Apr 29, 2025 | 09:06 PM
88n94's Avatar
88n94
Not a big deal. Just clean out around the spark plug with whatever method you use. Then you can try to tighten the spark plug or loosen it slightly and try tightening it. Or buy a new spark plug or a set and put it or them in after cleaning around the plugs. Note you probably won't notice the leak if still there until some oil or other liquid builds up around the plug again.
Old Apr 29, 2025 | 09:17 PM
88n94's Avatar
88n94
Whoops. I really missed that one.
Old Apr 29, 2025 | 09:24 PM
Jack Morgan
4wd Low
Missed as in, it’s actually a cracked cylinder head? 😭
Old Apr 29, 2025 | 09:48 PM
88n94's Avatar
88n94
[QUOTE=Jack Morgan;21557148]Missed as in, it’s actually a cracked cylinder head? 😭[/QUOTE
YES. When Conanski had a different answer(his post appeared while I was typing, I am a slow typer and even slower thinker) I knew I had to take another look. The liguid is coming through the spark plug from inside the cylinder. I assume you are losing coolant? Or you will soon notice that you are losing coolant. It could be a leaking head gasket though.
Old Apr 29, 2025 | 10:03 PM
Jack Morgan
4wd Low
[QUOTE=88n94;21557165]
haven’t been able to drive it much since I had to replace some other first so not sure if it’s losing coolant yet.
No exhaust smoke though, oil also looks good.
Truck does take some effort to get started though, gotta keep giving it gas or it’ll idle and die until it warms up. Kind of erratic RPM fluctuations & a real strong gas smell.
RPMs don’t seem to match the effort I’m giving the pedal though, light tap it might rev high, pushing down sometimes will kill the power/RPMs then be fine if I let up on it a little
Old Apr 29, 2025 | 10:16 PM
88n94's Avatar
88n94
You can probably tell that coolant is getting in that cylinder by removing that spark plug. You may have to use it a little longer to make it clearer to tell.
leonharu
Dec 12, 2024 05:58 PM
fordf348
Jan 14, 2022 11:38 AM
zarillus
May 22, 2008 08:05 PM
shwagy357
General Automotive Discussion
Feb 24, 2005 11:45 PM
