lowered 2012
Old Apr 28, 2025 | 02:45 PM
stan62's Avatar
stan62
5th Gear
lowered 2012
shortly after buying my pickup I lowered it w/ a Bell Teck kit. 57,000 miles later I had to replace the driveshaft ( joint at the carrier failed ) I decided to put a 2 1/2 degree pinion shim in to help my pinion angle. my problem is the bolts that go thru the springs won't be long enough to sit in the spriing saddle does someone make longer bolts to solve this problem? thanks for any help, Denny
Old Apr 28, 2025 | 06:11 PM
Evan76's Avatar
Evan76
Most any spring shop local to you can make nolts to your specs or oe specs just longer
_mtnbiker
Feb 25, 2019 08:55 AM
97powersmoke
1983 - 2012 Ranger & B-Series
Sep 14, 2013 06:38 AM
Zeitgeist57
Jan 7, 2013 08:04 PM
mpluxton
Nov 1, 2006 05:34 AM
