CHMSL Bed Camera Not working
Old Apr 27, 2025 | 01:23 PM
Cmelde01's Avatar
Cmelde01
As the title states my bed camera isn’t working. I can press the button on the screen and nothing happens. No dtcs are coming up on forscan I’ve tried doing the module reset and self test and everything seems to work correctly. I’m not getting a blue screen or anything. Anyone have any lead I’ve checked what I believe is the correct fuse and it was good.
Old Apr 27, 2025 | 02:01 PM
OBS460's Avatar
OBS460
Very common problem. Is it hot where you are or was the camera parked in direct sunlight? Before mine was replaced whenever it was 80F+ outside the camera wouldn't work. Call your dealer or replace it on your own dime. When replacing it on tour own you may lose the dashed lines on the camera without some programming.
Old Apr 27, 2025 | 02:32 PM
Cmelde01's Avatar
Cmelde01
I mean it’s it’s over 80 a lot here in Texas haha and yes it’s been parked in direct sunlight. Is it common for it to not blue screen at all and not have any dtcs? I find it weird that I have neither and when I hit the button in the screen it self it does nothing. It’s like acts like it doesn’t have the option but I have the icon to select.
Old Apr 27, 2025 | 03:25 PM
OBS460's Avatar
OBS460
Before I had mine replaced the 2nd time it would do the blank blue screen or it wouldn't do anything at all. I had a distorted image once and I took a picture of it and showed that to the dealer since it wasn't replicating the issue all the time.
Old Apr 28, 2025 | 09:47 AM
Mike Bartlett's Avatar
Mike Bartlett
There are a lot of camera recalls on the Ford Superduty trucks, my 2019 was repaired with the 20C19 recall. If you check online for Superduty recalls you will find a lot of info and videos. There may be a recall for yours but if not I’m sure some of the videos may provide a fix.
Good luck,
Mike
tacson
Nov 13, 2023 04:44 PM
jack orchard
2015 - 2020 F150
Jan 22, 2018 06:40 PM
fish-albuq
Dec 18, 2009 03:18 PM
Mark _G
Delaware Chapter
Apr 28, 2007 06:49 PM
