Undertaking a underslung straight axle
Old Apr 26, 2025 | 10:59 PM
stormystorm1's Avatar
stormystorm1
Good evening good morning hello,
I’ve got a 1957 f100 inline 6 truck it’s bare bones I and I want to keep it more traditional then the CV swap. I got a static drop so far of 4” around the truck and want a little more. The back end was flipped and I need to c-notch to get the full drop. The front end I shuffled the leafs a removed two.
But I want to go lower. I’ve got about 3” in between the oil pan and axle. I want to go underslung with welded in boxes.
The main thing I’m trying to sort out is the ubolt hole width and length. For the bottom of the axle I’d like to use a prefabbed leaf spring plate if possible to safe some time.
From what I can tell a jeep xj and yj leaf spring plate may work. I can get these for less than $10 if they’d fit it be a home run to weld them in top of boxing plates to my axle.
can anyone verify that? I can’t find a dimensions sheet or schematic anywhere that list the measurements?
As it sits now
As it sits now
When I first got her home
I plan to move the steering box up and adjust to make the steering right again. So bump steer I am planning to emlinate. This will never be a show truck just a static slam crusier for small town drives.
Old Apr 30, 2025 | 08:43 PM
FuzzFace2's Avatar
FuzzFace2
Have you looked into a dropped front axle beam this way you keep some space between the axle and oil pan and keep the suspension travel without bottoming out.
If I lower anything I like to keep the travel as close to factory as I can for the ride.
Dave ----
Old May 5, 2025 | 10:55 AM
JohnNewb's Avatar
JohnNewb
If you like slammed, it looks pretty good as it is. It would not make it down my road now.
Old May 18, 2025 | 06:23 PM
stormystorm1
holy cow I’ve been busy. It’s wierd times being a fed employee these days. Been more worried about losing my job then my project.
id like to eat pavement. So we’ll have to see. I’m mostly paved roads in the eastern sierra.
if I tuck too much I won’t be able to turn
Old May 19, 2025 | 08:06 PM
spurredon's Avatar
spurredon
I have a couple of trucks that look that low sitting in the lawn, but it is because their tires are flat and starting to sink in the ground! HaHa!
Old May 19, 2025 | 11:17 PM
stormystorm1
nice I’ve got a pretty good idea on a 2” spring plate and some bushing to get it under the axle.
funds are a shot tight with job uncertainty but hey YOLO
tjwebb
30
Apr 22, 2024 08:02 PM
Knockonwood
Aug 31, 2022 07:33 PM
AidenG
May 6, 2020 03:02 PM
Boostingaz
17
Jan 7, 2018 08:27 PM
Daggers
1947 and Older Ford Trucks
Mar 11, 2017 06:54 PM
