I bought the gasket and seal kit from Bronco Graveyard over a year ago for my 205. Im just getting around to using it now.
My front input bearing fell apart while removing and my speedometer drive gear wasn’t in the best of shape. I ordered that and a few small items like the linkage fiber bushings from Torque King. I ordered a new speedometer driven gear also. Figured I should do the set. Plus I ordered one that will hopefully get my MPH more accurate.
I was looking at their rebuild kit and wasn't sure if people had any issues with it.
That's where I grabbed rebuild kits for my NP205, T18, 9 inch rear end and D44 front.
They source their kits from Yukon Gear/USA Standard Gear, I think the differential kits were in a Yukon box and the trans and xfer kit were USA standard box as I recall.
