Ac issues
Old Apr 21, 2025 | 04:39 PM
bushwacker4x4's Avatar
bushwacker4x4
1st Gear
Ac issues
I have a 2002 F350 with 200K miles on it. My AC works fine as long as I am driving but once I stop it gets worm. I have checked my high and low side charges and they are perfact. I added an electic fan to the condenser but it stil does it. I have checked the cluch and it is fine. Do you think my compressor is getting week? Fyi at a stop light if I put my truck in neutral and rev the engine to 1200rpm and stays nice and cool.
Old Apr 21, 2025 | 06:09 PM
Old and soft's Avatar
Old and soft
I have had both a 99 and a 01. The ac system just isnt anything to get excited about. Compressor clutch air gap. Set by the thickness of washers under the small bolt on the front of the compressor. On my 01 I had to adjust to restore proper operation of compressor clutch. Don't remember much about it, I did that like 8 years ago. Some searching should find it for you. Not saying it is the sure cure, but somewhere to look.
Old Apr 22, 2025 | 09:32 AM
Mike Bartlett's Avatar
Mike Bartlett
I think you’re in the wrong forum, this is 2017-2022. You will likely get better related feedback from the 2002 group.
Good luck,
Mike
Old Apr 23, 2025 | 05:19 AM
Smokeatrr's Avatar
Smokeatrr
Had an 03 7.3 with same issue at 220k miles. Change out the engine fan clutch and ac compressor. Found a lot of debris in the screen going to evaporator. i think that the restriction and worn compressor was the most likely the problem.
Glennc6
Large Truck
Jul 23, 2024 01:50 PM
BowlerGT
Apr 22, 2021 09:53 AM
QwkTrip
2015 - 2020 F150
24
Jun 16, 2016 06:14 PM
88fordf150
Jun 11, 2005 08:31 PM
Chris_ce
1983 - 2012 Ranger & B-Series
Jul 6, 2003 08:44 AM
