Fuse box
Old Apr 20, 2025 | 05:09 PM
Daniel Yosef's Avatar
Daniel Yosef
Fuse box
Hey guys. 67 f100. I have a bunch of wires going directly to the key switch post, so I got a fuse box to make things a bit safer. I put the fuse box in place, and the power supply comes from the switch, ground to body.
truck will crank and start but die once I let the key go.
any help? What I’m doing wrong?
Old Apr 20, 2025 | 06:47 PM
fe390pc's Avatar
fe390pc
You are missing the key on power to the distributor. You have the bypass wire still from the solenoid. It will be a resistive wire that knocks done the voltage to about 9v.
Old Apr 20, 2025 | 06:49 PM
Daniel Yosef
From the solenoid to ballest, then to coil.
which wire are you referring to?
Old Apr 21, 2025 | 08:59 AM
fe390pc's Avatar
fe390pc
It would be from the ignition switch.
Old Apr 21, 2025 | 09:00 AM
fe390pc's Avatar
fe390pc
Here is the wiring diagram.
2007FEH
Escape & Escape Hybrid
Sep 12, 2018 05:14 PM
Jterr
Apr 5, 2017 03:48 PM
Michaelshawnbradford
Feb 24, 2015 12:59 PM
NickOlsen53
Apr 13, 2014 02:11 PM
AtlPikMan
Mar 25, 2009 01:13 PM
