Fuse box trouble
Old Apr 12, 2014 | 03:25 PM
NickOlsen53's Avatar
NickOlsen53
Fuse box trouble
The upper part of the fuse box, like the turn signal and heater fuses don't have power, but everything else works
Old Apr 12, 2014 | 06:07 PM
Franklin2's Avatar
Franklin2
Part of the fuse box is fed from the ignition switch, part of it is fed from the battery directly. See if the problem is with all circuits that are on only with the key. If that seems to be the problem, lightly wiggle the ignition switch back and forth after you start the truck. It's a common problem for these trucks to lose some electrical because the keyswitch doesn't return back to the proper position.
Old Apr 13, 2014 | 02:11 PM
NickOlsen53
Thanks franklin it worked!
purecty
Jul 25, 2022 11:06 AM
joeimp
Electrical Systems/Wiring
Jan 15, 2018 07:33 AM
Crewdcab
Apr 28, 2016 12:01 PM
AtlPikMan
Mar 25, 2009 01:13 PM
TAF
Mar 31, 2008 02:36 PM
