Electrical Gremlins
Old Apr 18, 2025 | 11:27 PM
FourCyxty's Avatar
FourCyxty
4wd Low
Electrical Gremlins
Pulled a 1993 F250 460 out of the weeds. I have a couple electrical issues that I’m looking to resolve if possible.
I replaced the fuel filter, gas tank and fuel pump on the front tank. The gas gauge is reading half at empty and completely pegged at full.
The wipers won’t move on intermittent settings but will at constant.
The stock radio volume fluctuates up and down at random without touching it.
Old Apr 19, 2025 | 02:58 AM
Prototypemech's Avatar
Prototypemech
Inaccurate gas gauge is usually a problem with the sending unit inside the gas tank. You can use a ohm meter to measure the resistance at the sending unit vs the resistance at the fuel selector switch on the dash to confirm. You may try disconnecting the main taillight harness underneath the brake master cylinder and reconnect it, with the hope of breaking some corrosion loose.
The wiper controller is behind the glove box. You may be able to repair it by removing it and tapping on it to break the relay contacts loose. Don't confuse it with the RABS computer.
If you're handy, you can disassemble the front face of the radio and clean up the radio button contacts with rubbing alcohol. I've been surprised how much electronic stuff I can fix with alcohol.
Old Apr 19, 2025 | 09:25 AM
manicmechanic007's Avatar
manicmechanic007
There is diagnosis and testing of the governor in the shop manual and some in the '93 EVTM
I'd replace the intermittent wiper governor with a known good one and retest (the electrical pinpoint testing is a bit difficult)
It's one of the ones where substitute a known good part comes into play
I have a good used governor in my toolbox (still) because of this
The governors very seldom fail
I think I replaced 4 or 5 in 30 years
I'd find a 1993 EVTM (or use AllData at your library) and do some of the wiper switch pinpoint testing for no intermittent wiper function first
Dirtbikeguy
Oct 13, 2021 05:55 AM
tbruz
17
Nov 29, 2015 02:05 PM
johnknutson
Oct 9, 2015 06:30 AM
Dadzilla
1983 - 2012 Ranger & B-Series
Jan 25, 2006 08:58 AM
Soaphauler
Jul 9, 2005 11:54 PM
