I recently put a new EVP on, (actually old, pulled it off a parts truck) and that fixed some of my codes, but I was stuck with 33 and 41, both relatively recent. I think this broken line explains both. In the meantime, I wrapped it in gorilla tape.
My question is, what do you guys use to replace these lines? And if it's the same size as the white HVAC line, I need to replace that one as well.
If that is the only bad part then I would use a small piece of vacuum hose the patch it back together.
I don’t know off the top of my head since I have never replaced the nylon tubing with rubber or silicone hose. There are threads here and on fullsizebronco.com that go over replacement and hose sizes.
