No start/no gauges
Old Apr 14, 2025 | 06:27 PM
kelila.bayless's Avatar
kelila.bayless
2nd Gear
No start/no gauges
I have a 2005 Ford F150 with a 4.6L. I recently had issues with my front airbag sensor, so I removed it planning to replace it. I started it up, noticed that my gauges took a second to come on.
Then I drove it the next day, it started up and no gauges came on. No gauges, no radio, no power windows, no odometer, no hvac controls.
When I got back, I shut it off and when I took the key out and opened my door my blower motor turned on and it started blowing, as well as my flasher relay started clicking.
Now it wont start at all, no crank, no click. I went to the starter relay and bypassed it, and it started cranking but still no start.
Is there a safety mode when anything with the airbag is messed with? Maybe something with the restraint control module?
Old Apr 15, 2025 | 04:53 AM
techrep's Avatar
techrep
what was the issue with the airbag sensor ? I would re-install it and see if you get everything back.
Old Apr 15, 2025 | 09:58 PM
kelila.bayless
2nd Gear
Unfortunately it was having issues, so I just got rid of it. I tried using another one from a 2007 model, but no luck. I'm not sure if programming or anything needs to happen.
Brewer84
1997 - 2003 F150
16
Jan 2, 2024 04:55 AM
TikiRick
Mar 21, 2018 06:03 PM
73fxe
2009 - 2014 F150
Apr 9, 2016 09:30 PM
Map Man 1
6.7L Power Stroke Diesel
Jun 17, 2014 03:44 AM
FORDSRULE98
1997 - 2003 F150
Nov 26, 2008 04:58 AM
