Identify Sensor?
Old Apr 14, 2025 | 10:43 AM
Flaman's Avatar
Flaman
Question Identify Sensor?
Picture is of electrical component under charge air pipe on my 2004 Powerstroke 6.0. Electrical connecter on sensor is cracked and I need to replace it. I've done a bunch of searches, but I am not even sure what to call it.
Yellow arrow points to sensor
Old Apr 14, 2025 | 01:14 PM
joe blow's Avatar
joe blow
It appears to be the throttle body the '04's came with. You can actually remove the butterfly inside and call it good. I actually removed the entire throttle body as it serves NO purpose and most program updates removed it from the strategy years ago. I purchased a nice SS rounded elbow with vacuum ports and it bolts right to the manifold, if you choose to ditch the throttle assembly. Your '04 elbow is restrictive and squared internally.
I am sure someone else will chime in. As for the connector, I would not worry about it.
Preview image for a collapsed post.
Old Apr 14, 2025 | 10:37 PM
tfunk88's Avatar
tfunk88
Maaaan, I’m glad you knew what that was! I looked at it and thought “What in the world? I don’t have anything like ANY of that on my truck!” 😂
Old Apr 15, 2025 | 06:37 AM
TooManyToys.'s Avatar
TooManyToys.
No components were under those covers on my truck's Ford '03 reman; it was just a place to pull the connectors so the wires were supported.
Jaaaaaaackman
Aug 12, 2024 10:05 AM
dannac
2015 - 2020 F150
Jun 10, 2023 09:03 AM
Cowboy923
Oct 5, 2020 11:03 PM
cpettymore7777
Apr 20, 2011 07:32 AM
cdiddy
17
Dec 31, 2006 02:24 PM
