BMS sensor 2017
Old Mar 6, 2023 | 11:14 AM
dannac's Avatar
dannac
BMS sensor 2017
2017 Ford F150
Is this the BMS sensor ?
If I were to disconnect would the separation be at arrow point ?
Old Mar 6, 2023 | 11:44 AM
Robbgt's Avatar
Robbgt
It is BMS sensor, but I believe that entire piece to the right disconnects as well. Should be a tab underneath I believe
Old Mar 6, 2023 | 01:41 PM
dannac's Avatar
dannac
It is as you mentioned, the larger section towards right is where it separates.
Thank you.
Old Jun 10, 2023 | 09:03 AM
redbug's Avatar
redbug
Ok, I will reattach it when I find where the cut it from. ...... must be within 4 inches of the sensor because that's the length of the cut wire.
Cowboy923
Oct 5, 2020 11:03 PM
4x4pwr
Modular V10 (6.8l)
Jun 7, 2016 12:05 AM
mcali2
Apr 1, 2016 11:38 AM
cpettymore7777
Apr 20, 2011 07:32 AM
cdiddy
17
Dec 31, 2006 02:24 PM
