P0402 6.7
Old Apr 13, 2025 | 05:57 PM
trav95's Avatar
trav95
Trailering
P0402 6.7
Have a 2012 f-250 6.7 with 165k miles. Deleted it at 75k and ran perfectly. Since I live in California the smog shop said no pass as their system can detect issue even though it was tuned back to stock and old dpf bolted back. So mechanic cleaned out def tank and lines,def sending unit, replaced egr valve, egr housing egr cooler and replaced computer. It still has P0402 code (excess egr flow) and he said he has run out of ideas to fix, any suggestions? He’s had it for 6 months. Map sensor is clean, air filter new, truck runs fine. Clear code and cel light and code comes back within 50 miles. Any suggestions? At wits end
Old Apr 13, 2025 | 07:34 PM
Dustin F450's Avatar
Dustin F450
When you deleted it, did you pull off the egr or just unplug it. If you just unplugged it and ran it deleted like that, plugging it in will not work. Replace the whole egr valve with a new Motorcraft.
Old Apr 13, 2025 | 07:59 PM
trav95's Avatar
trav95
Trailering
Egr
Thanks Dustin. Yes installed new motorcraft egr valve, housing and cooler, actually tried 2 different egr valves to make sure
Old Apr 14, 2025 | 07:56 AM
scottu5's Avatar
scottu5
Hi,
I would check CAC (cold side tube, no leaks cracks), next, the Exhaust Back Pressure (EBP) sensor. Also, that there are no leaks/blockages in the Air Filter / housing or the sensor.
Old Apr 14, 2025 | 09:53 AM
speakerfritz's Avatar
speakerfritz
p0402 is based on changes in MAF data...as more egr flow occurs...less MAF should be happening...assuming your CCV is stock.
so when I had the code I replaced the MAF sensor and MAP and still had the code. replaced the IAT...still had the code. replaced the EBP sensor...code gone. dont know if it was a coincidence....maybe the system had to do a relearn after MAF and MAP replacement. I do know that clearning a p0402 with a scan tool does not work...its a perm code and only clears after the PCM verifies the condition is fixed.
Old Apr 14, 2025 | 07:41 PM
trav95's Avatar
trav95
Trailering
Thank you
Thanks for the suggestions!
Old Apr 15, 2025 | 12:34 PM
speakerfritz
i forgot to mention, the EBP takes two wrenchs to remove,,,if you try to use only one wrench..you will break the tube that the ebp connects to.
and....the ebp is on the pax side of the turbo almost in line with the hood vent area.
trav95
May 4, 2025 09:56 PM
runwayz
Nov 18, 2019 09:57 PM
ESCAPESTER
Escape & Escape Hybrid
Oct 13, 2008 09:31 PM
LeroyB3000
1983 - 2012 Ranger & B-Series
Jul 15, 2007 11:48 AM
bhildreth
Nov 25, 2006 09:15 AM
