Beake Light Switch Missing
Old Apr 16, 2025 | 07:18 PM
manglass's Avatar
manglass
There should be two wires from the parking light/blinker type of housing. The original parking light wire will go into one lead and the turn signal in the other. The easy way to tell them apart is that the blinker should be brighter than the parking light. I made this conversion on my own truck and it worked out perfectly.
Lou Manglass
Old Apr 16, 2025 | 07:32 PM
JohnNewb's Avatar
JohnNewb
Lou Manglass
Mine has single wires, single filament bulbs. Everythingthing has the stock butt connector plug-ins. Fender mounted turn signals were single wire too. The donor truck had two wire lamps but it looks like too much work to change them
Old Apr 16, 2025 | 08:31 PM
manglass's Avatar
manglass
You can replace the lamp assemblies or replace the sockets with dual contact models. Otherwise, I think the easier way would be to position a marker light (maybe behind the grill?). Or run a side marker light bulb and socket into the parking lamp assembly. Use the marker light as your parking light and the original parking light as your turn signal.
Lou
Old Apr 16, 2025 | 08:43 PM
JohnNewb's Avatar
JohnNewb
Lou
I have the two wire lamp assemblies from the donor but don't want to disassemble the grille to install them. Where can I buy a bulb socket that I can install by just removing lens?
Old Apr 16, 2025 | 08:45 PM
JohnNewb's Avatar
JohnNewb
Can I access the lamp housings mount nuts from underneath? Without removing everything?
Old Apr 16, 2025 | 08:57 PM
manglass's Avatar
manglass
Look here for sockets: https://www.rockauto.com/en/tools/el...al+socket,4092
Unless you have a 1960 grille in your '59 you should be able to change parking lights by removing the two nuts on the back. You can access them from underneath or through the wheel well, turn the front of the tire away from you and you should be able to get in there to work on it.
Lou
Old Apr 17, 2025 | 12:22 PM
JohnNewb's Avatar
JohnNewb
Lou
The inboard nuts are behind the radiator support but it looks like I made holes to access the nuts years ago when I did the cab swap. It's no fun getting old.
Old Apr 17, 2025 | 07:43 PM
spurredon's Avatar
spurredon
[QUOTE. It's no fun getting old.[/QUOTE]
It's not that bad, at least it is something new every day even if it isn't! LOL
thor363
Sep 7, 2024 05:53 PM
Dodgeyaussie
Aug 3, 2024 11:09 PM
mh_merc
1947 and Older Ford Trucks
May 2, 2024 04:01 PM
Toork
Jun 19, 2021 09:10 PM
GT350HR
Oct 15, 2020 03:32 PM
