Electrical issue
Old Apr 13, 2025 | 12:36 PM
Monzadu's Avatar
Monzadu
4th Gear
Electrical issue
I have a 1999 ford f250 with a 7.3 diesel I am I. The process of changing the cab and frame I just got it running and now I am having an issue where when it is running and I go to put it into four wheel drive all the gages stop working and the dome light and top brake light flash. I have checked all the grounds and all the sensors making sure it is grounded and everything is plugged in correctly I am at a loss as of this point and any suggestions would pe appreciated thanks
Old Apr 14, 2025 | 06:06 AM
pvdiag's Avatar
pvdiag
Guessing you have electronic shift on the fly. I would revisit the grounding. Does the 4wd engage and work when this happens?
Old Apr 14, 2025 | 08:23 AM
Monzadu's Avatar
Monzadu
4th Gear
No it is a manual shift
Old Apr 14, 2025 | 11:53 AM
pvdiag's Avatar
pvdiag
Possible that you have some wiring that gets pinched by the shift lever? Specifically the wiring the provide 4wd feedback to the dash panel.
Old Apr 14, 2025 | 10:01 PM
Monzadu's Avatar
Monzadu
4th Gear
I have been over that as well it also happened when the 4*4 lever wasn’t even on the truck yet because I took it out of 4*4 with a pair of pliers
titanjas
Apr 19, 2024 02:56 PM
XLTaterTots
Sep 15, 2022 03:46 PM
Raining wrenches
Apr 14, 2022 02:17 AM
dhag911
Aug 7, 2021 02:40 PM
Mizuez
Feb 23, 2016 08:12 AM
