Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Vin Engine Code W 1975
Old Apr 12, 2025 | 12:39 PM
betterwhale01's Avatar
betterwhale01
2nd Gear
C75wvx09253
1975 C750, Tilt Cab, Gas
W unknown engine (it’s a gas V8)
Made in Kentucky
in May 1975
any info on what the engine is??
Old Apr 12, 2025 | 05:04 PM
85e150's Avatar
85e150
Welcome to FTE!
W = 361 2BBL "Low propane gas" Domestic Special Order engine. (MY '73 to '77. This code was also used for the 361 4BBL "Low propane gas" for MY '76 to '78)
It's an FT engine and appears it might have been converted back to gasoline? (Based on the non-eom air cleaner)
Old Apr 15, 2025 | 05:54 PM
betterwhale01
2nd Gear
Originally Posted by 85e150
Welcome to FTE!
thanks! It is still ran on propane. Trying to get it running but the wiring is a mess and the starter is bad(post spun). Needing a new starter. Rockauto says AC Delco 336-1007 fits but it also says it fits the light duty trucks, and I believe they use different starters. It has an Allison AT545
Old Apr 15, 2025 | 06:34 PM
85e150's Avatar
85e150
It seems the FT will use an FE starter, but as OEM they were different part numbers iirc.
Post 2 for FT number, post 4 for a link to another thread where the FE on FT starter is discussed.
https://www.ford-trucks.com/forums/1...l#post16988779
maxtegracing
Jan 6, 2022 11:27 AM
Tim charron
May 21, 2020 04:11 PM
msquared100
Nov 8, 2009 07:18 AM
pjlandry
Dec 17, 2006 11:36 PM
hawkrod
Apr 11, 2003 01:11 AM
