351M/Cleveland headers
Old Dec 4, 2003 | 10:02 PM
78ford100's Avatar
78ford100
I'm putting a Cleveland (2bbl) in an 89 Bronco. I saw in Summit that Dynomax offers a set of headers for 80-95 Bronco and F-150 4x4 with 351M/400. Is there any reason I can't use those?
Old Dec 6, 2003 | 10:38 AM
Bill_Beyer's Avatar
Bill_Beyer
In my experience long tube headers are very much application specific. Even getting long tube headers into the vehicle/engine combo they were made for can sometimes require modification. You'd probably be better off going with Sanderson type shorty Cleveland headers.
Old Dec 8, 2003 | 04:34 PM
cid473's Avatar
cid473
these headers should work since there is only about 1 inch difference in height between the C and M blocks. this might put the left header below the oil pan, but should allow more clearance at the front diff., which should allow more room for exhaust.
Old Dec 8, 2003 | 05:25 PM
Bill_Beyer's Avatar
Bill_Beyer
BTW the only listing I could find for the 80-95 Bronco and F-150 was for the 302 engine. The 351M/400 headers are for 78-79 models.
Old Dec 8, 2003 | 08:19 PM
78ford100's Avatar
78ford100
I'll probably end up buying a set, cause nobody else makes headers for that application. (that I know of) I'm pretty sure shorty headers won't work because of frame clearance. The summit part # is WLK-85053, Jegs is 289-85053.
Old Dec 8, 2003 | 08:33 PM
Bill_Beyer's Avatar
Bill_Beyer
That's a really strange way to list those headers since the 351M was retired in 1982. I guess for $119.00 it's not too big a gamble. You can always off them on eBay if they don't work.
You might still want to look at the Sanderson pieces.
Sanderson Cleveland/Midland Headers
Old Dec 8, 2003 | 09:51 PM
There Goes The Neighborhood's Avatar
Hedman part no. 89330: 1 5/8 primaries
Hooker Comp. part no. 6916: 1 3/4 primaries, 2 1/2 inch collectors
Hooker Super Comp. part no. 6827: 1 3/4 primaries, 2 1/2 inch collectors
All for 1980-1985 F150, Bronco
These have the same frame as an '89 Bronco.
351Cleveland C4
17
Feb 7, 2015 10:49 PM
351Cleveland C4
Dec 19, 2013 03:59 PM
Hensley1027
36
Mar 16, 2011 01:07 PM
johnson2007
Nov 15, 2010 05:17 PM
84Maztang
Jun 13, 2003 04:58 PM
