up upipes
Old Apr 7, 2025 | 09:43 AM
symonds86's Avatar
symonds86
up upipes
anyone installed a 1 piece up pipe can you do it without dropping the auto transmission?
Old Apr 7, 2025 | 10:27 AM
97-psd's Avatar
97-psd
I think all up pipes are one piece. Are you talking about a down pipe?
Old Apr 7, 2025 | 10:29 AM
knottyrope's Avatar
knottyrope
there are two pipes, cant be done with one piece that i can imagine
Trans dont have to be removed ( 1 hour) , but you will have many many hours of fun getting to bolts with extensions, swivels and creativity if you dont remove the trans
Old Apr 7, 2025 | 10:34 AM
symonds86's Avatar
symonds86
ok thank I saw this and I got me wondering https://rudysdiesel.com/products/rud...pr_seq=uniform
Old Apr 7, 2025 | 10:43 AM
symonds86's Avatar
symonds86
ill have to get a better look at the truck and see how bad they are if i can hold off till fall i will have the trans out anyway
Old Apr 7, 2025 | 01:59 PM
97-psd's Avatar
97-psd
The ad for the part says that it can be installed from the top without transmission removal. Looks like a good price on it.
Old Apr 7, 2025 | 03:55 PM
Hit Man X's Avatar
Hit Man X
$175?
Run away. Irate I believe had a one piece and probably fits, it was $500-600. That unit looks like junk and I would rather drive with leaking OE uppipes
Old Apr 8, 2025 | 10:49 AM
Kaleb_Lee's Avatar
Kaleb_Lee
1st Gear
https://cpaddict.com/products/diesel...ed-up-pipe-kit
I just did this kit on a OBS with an auto, you dont need to drop the trans. If you do the multi-piece set, go in from the top, drivers side firewall with need to be tweaked with prybar but it will go after a lot of twisting and cussing. Same with the passenger side, go from the top and go underneath to move around the tranny dipstick. I had the turbo pulled to do the E-fuel system, if you dont plan on pulling the turbo again I would just spend the moeny and get the new pipe while you are there.
Old Apr 8, 2025 | 03:32 PM
tshrager's Avatar
tshrager
Originally Posted by Hit Man X
$175?
Im not so sure about that. I don't care how it "looks" if it is indeed functional. I installed some very shoddy (cheap) up pipes on my old SD and they worked just fine. If a guy is on a budget, sometimes you gotta roll the dice to save 3-400 bucks.
lght1
Dec 12, 2013 10:01 PM
96_F250_Deezal
Feb 1, 2012 04:49 PM
ghunt
General Automotive Discussion
Jan 15, 2008 09:20 AM
Vanhecht
Exhaust Systems
Nov 2, 2003 03:06 PM
TRIMMAN98
May 7, 2002 11:00 AM
