Eaton 2 speed torque spec
Old Apr 7, 2025 | 06:15 AM
49F5's Avatar
49F5
4wd Low
Looking for a "torque spec" for the main bearing caps on my eaton 1350. My manual says "very tight". I marked the bolts before I took them apart and once I tightened them down to the mark the value came about 40ftlb. That just seems low to me.
Old Apr 7, 2025 | 11:17 AM
52 Merc's Avatar
52 Merc
Lacking a factory specification, you can look up torque values on an online chart that would show a recommended torque for specific types of bolts, by size, grade, length, thread, etc., and go with that. You just want to be careful about possibly over tightening the bearings. Then there's always the spec, "Bob tight", what we called things put together by my late friend who was larger and stronger than the average man. He always made sure his fasteners wouldn't come apart, which sounds perhaps like what the book is calling for.
Old Apr 7, 2025 | 11:39 AM
56panelford's Avatar
56panelford
I goggled this if it helps at all I think you are pretty close
Old Apr 7, 2025 | 01:24 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Oh gosh, let's not blindly trust the AI search results. Take the example here:
https://www.ford-trucks.com/forums/1...l#post21298379
In my following post on that thread, I show how to get to the underlying AI source and find its folly. You should do the same and cite the actual source if it does happen to be correct.
Old Apr 7, 2025 | 07:40 PM
85e150's Avatar
85e150
There are multiple Eaton publications on line, even for older stuff. There are PDFs with torque specs etc.
These things don't link very well as the address becomes too long.
But if you do a search with "Eaton 1350 torque specifications" you'll find Eaton stuff by the bushel.
And yes, avoid anything "AI". Too new, not reliable.
Anonymous12
Aug 11, 2023 04:56 PM
Diesel Smoker
Sep 20, 2007 07:54 PM
1987_f150
Nov 17, 2006 07:39 AM
TDF
Modular V8 (4.6L, 5.4L)
Jun 4, 2003 02:01 PM
