Main Bearing Cap torque Specs
Howdy Folks, Long time listener, first time poster. I have a 99 F250 Superduty that I'm replacing the engine in (last owner ran it out of oil) and I need th know the torque specs for the main bearing caps. I bought a chilton's manual and believe it or not they don't have that torque spec in their manual, everything else but not the main bearing caps.
Can anybody help me out.
Thanks
Thanks
Sorry, I have a 2002 5.4 and the manual says
install vertical crankshaft cap bolt to 30 ftlbs and then tighten another 85 -95 degrees ???????
Never heard of that before!
Then install side bolts to 22ftlbs and tighten another 85-95 degrees
There is also a sequence order to tighten them to
You better find a better manual to help you
2002 might be different
Rich
Rich
JaysRanger
10-30-2009 11:48 PM
beaners1
06-10-2008 05:55 PM
