Sponsored by: Real Truck
What causes this?
Old Apr 4, 2025 | 04:21 PM
brienkd's Avatar
brienkd
Trailering
What causes this?
2011 F250 6.2 104K I took my truck out of hibernation and went for a ride. I noticed a little chugging at light throttle in 6th gear. Then later after a good ride the check engine light starts flashing and I have no power. I came to a stop and the light went away and it ran normal for a while. Hooked up Live Link and did a data log and this is what stands out. Any idea what caused this spike? Shouldn't that value be close to 1? What else should I be looking at?
Thank you all in advance for your help.
Old Apr 4, 2025 | 10:30 PM
Boaterguy's Avatar
Boaterguy
Flashing check engine light is usually a misfire. What was the code registered?
Old Apr 5, 2025 | 08:48 AM
brienkd's Avatar
brienkd
Trailering
I immediately pulled over and checked the dtc tab. No code. I am going to monitor the misfire PIDS.
Old Apr 5, 2025 | 02:08 PM
brienkd's Avatar
brienkd
Trailering
Threw a code. P0307 cylinder 7 misfire.
Old Apr 6, 2025 | 01:38 PM
brienkd's Avatar
brienkd
Trailering
Turns out that coil is missing a resistor. So $64K Q. Where do I get a resistor? The service manual does not show it in the ignition component exploded view.
Old Apr 6, 2025 | 01:44 PM
Pikachu's Avatar
Pikachu
The resistor that goes between the coil and the spring in the boot? They usually come with a replacement boot kit.
Old Apr 6, 2025 | 02:08 PM
brienkd's Avatar
brienkd
Trailering
Yes that resistor. Replaced all coils wires and plugs. Apparently they neglected to include a resistor for that coil. I suppose I will have to get a replacement boot.
fabian.219
Aug 31, 2023 09:11 AM
3.3
2015 - 2020 F150
13
Mar 3, 2023 03:54 AM
ramirez7589
Jun 22, 2015 09:42 AM
FX4Filley
2004 - 2008 F150
Dec 14, 2007 10:18 AM
Mr.Ford 351W
Garage & Workshop
May 6, 2006 10:40 AM
