Sponsored by: Real Truck
Reverse issues (5 speed torq shift)
Old Apr 4, 2025 | 12:32 AM
Mykah knabe's Avatar
Mykah knabe
Recently, my 5r110w has had some reverse issues along with some other concerns. 90% of the time it goes into reverse perfectly, however sometimes after I've been driving for a bit, drive to reverse has about a 1.5 second delay, or a jerk from park to reverse. This maybe happens once a week. Also when it was warmer out, I noticed that once the transmission was up to temp, it would bark a bit at the last half second of a full stop and first half second of acceleration from a full stop. It hasn't done that scince. The transmission never slips, shudders, nor does it have any issues with any forward gears shifts. Fluid is nice and red, no foam on the dipstick, no overheating, no other issues(knock on wood) fluid and filter were changed 3k miles ago. Truck is a 2005 f350 v10 with 134k miles. Hoping that this is just an older transmission being quirky.
Old Apr 4, 2025 | 08:32 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What fluid did you use when you changed it?
What codes are stored in the PCM?
Old Apr 4, 2025 | 09:07 AM
Mykah knabe
I used valvoline max life atf dex/merc, which I've been running in it for awhile. The only code on the pcm is a abs module communication error. (I forgot the code number)
Liquid10Rider
Jan 17, 2023 09:12 AM
Patina65
May 16, 2021 06:53 PM
chrison600
Oct 13, 2012 12:56 PM
elotus
Aug 25, 2011 08:23 PM
Black05
Mar 3, 2006 08:51 AM
