XP assistance
Old Dec 4, 2003 | 08:49 PM
88grandmarquis's Avatar
88grandmarquis
Question XP assistance
Couple of questions.
1. It seems to be running a bit sluggish. Any way to speed it up? There seems to be a lot of things running when I go under "start-run-msconfig-services". Anyone know if thinning out the running programs will help speed it up? Anything that I should keep running?
2. I can't upload any images on any sites. It will sit and think for a few minutes, then say "page cannot be displayed". Nothing I do seems to work. Wondering if anyone can help.
Thanks. Sorry for the many Q's, but I'm trying to adjust to XP.
Edit: Just found over a dozen WinXP "hotfix" programs under "add/remove programs". What are these and why so many? Can they be removed?
Old Dec 4, 2003 | 09:28 PM
Andysutt's Avatar
Andysutt
The hotfix is updates from Windows
leave them, you'll need them.
Im not sure on what to delete, as Im not sure exactly what you have installed. but maybe the slowness uploading images is your internet or your PC?
Old Dec 4, 2003 | 10:14 PM
wesg's Avatar
wesg
Cool
Hey 88GrandMarquis,
See if these are any help. I do not use XP, I prefer to stick with Win98 and am playing with Linux. These are from a newsletter I subscribe to.
"Ten Ways to make Windows XP Run Better" http://www.informationweek.com/story/IWK20011204S0009
"System Setup Secrets For XP," and it's at http://www.informationweek.com/story...cleID=12803122
wes
Old Dec 4, 2003 | 10:50 PM
hyepwrd's Avatar
hyepwrd
Re: XP assistance
1. yes. a lot of programs normally start themselves up with the computer by default when you install them and you have to take them out. if not they run in the background. its probably the best thing to do, assuming you do defrag and cleanup frequently.
2. probably firewall settings, if not, internet explorer settings.
hope that helps. if someone can get more technical, they'll just roll eyes at my reply and give you more. good luck.
Old Dec 4, 2003 | 11:22 PM
modru2004's Avatar
modru2004
first of all disable any programs you do not need running all the time so they do not run at startup, this keeps you from having to open task manager and close them. you can close anything that says its being run by the user, if its system its best to be left alone unless your an expert user, as some of them can be closed off. go to run and type in msconfig and go to the startup tab, thats where you can stop the programs from loading. other than clearing out excess background programs you can't do anything more for your performance unless you want to upgrade. when you say images im assuming that it won't load webpages? what type of internet connection do you have? dialup or broadband? and did it just start doing this out of the blue? if it just started happing the servers at your isp could be having issues. also note that some windows hotfixes can slow your computer or even cause worse issues. so i would leave those be unless you know what your doing. defrag and make sure your hd isn't fragmented into a jillion pieces, as that will hurt performance.
Old Dec 5, 2003 | 04:45 AM
droptop's Avatar
droptop
Is this slowdown happening when you are on the internet? (The reason I'm asking is because of your second question) Get Spybot Search and Destroy and run a scan on your computer. Spyware/malware can cause a tremendous slowdown on your computer.
As for the hotfixes, your machine probably has Windows Automatic updates enabled and is downloading and installing the hotfixes on it's own. It makes it easy because you don't have to remember to check for updates, but you also get every patch that Microsoft puts out for XP. Many of them you may not need and/or are not applicable to your situation. I pick what hotfixes to download and I never take what Microsoft says I need at 100% face value.
cjben
17
Sep 9, 2007 05:27 PM
triplethreat
17
Jun 20, 2004 04:37 AM
TrunkSlammer
Jun 16, 2004 02:01 AM
theologian
34
Sep 16, 2003 10:26 PM
Shepard
Jan 2, 2003 07:10 PM
