351m engine help
Old Apr 2, 2025 | 02:37 PM
Nathan ozias's Avatar
Nathan ozias
351m engine help
I am rebuilding a 351m from my 1980 f-350 and it is currently at the machine shop getting bored to .40 over. Will I be able to use the stock cam? I assume not but want to make sure before I spend money on a new one.
Old Apr 2, 2025 | 02:45 PM
Max Capacity's Avatar
Max Capacity
You can use the stock cam. it doesn't care what size pistons you have.
Depending on the shop, they may have thoughts on a better cam if you want a little more power, as if you were towing.
What are your plans for the truck ?
Old Apr 2, 2025 | 03:06 PM
Nathan ozias
It going to be my daily driver that I plan on doing a little towing with
Old Apr 2, 2025 | 03:12 PM
Max Capacity
Towing, a big trailer or just a small lawn mower size trailer. We need info.
If you don't mine spending the money for a cam kit, you can do some research on, say Summit Racing, Jegs, Crane Cams, etc They all have great customer service and tech support. They will be more than happy to help spend your money.
Old Apr 2, 2025 | 03:52 PM
Nathan ozias
Towing small stuff for now I plan on putting in a 460 later on but for now I just need the vehicle to run and have decent power.
Old Apr 2, 2025 | 04:36 PM
Franklin2's Avatar
Franklin2
With the quality of the parts you get now, I would stick with the original cam if the machine shop thinks it's ok. I have never felt any seat of the pants difference with small camshaft changes on a otherwise stock engine.
If the machine shop thinks you should change it, see what brand they recommend for long service.
Old Apr 3, 2025 | 08:36 AM
kr98664's Avatar
kr98664
Originally Posted by Max Capacity
Towing a big trailer or just a small lawn mower size trailer? We need info.
Yes, and what color is the trailer?
Can't help with the cam question, but no matter what you choose, be very careful with the break-in procedure. If the shop offers a warranty, be sure to follow their recommendations exactly. My sad tale about break-in here:
https://www.ford-trucks.com/forums/1...brication.html
Old Apr 3, 2025 | 09:01 AM
Max Capacity
I was thinking it was going to be something like this,
Old Apr 3, 2025 | 12:13 PM
Nathan ozias
As I’m getting ready to start assembling the engine I was wondering if what bolts need to be replaced and is there a kit you can get that has all the bolts you need?
Nathan ozias
That is pretty much what I will be pulling
Old Apr 3, 2025 | 12:52 PM
Max Capacity
The head bolts would be the only ones I would do. as all the others are just bolts. ARP is who I would use, but if your not looking for high Performance stuff, just price them from your local auto parts store.
Old Apr 3, 2025 | 01:58 PM
Franklin2's Avatar
Franklin2
The head bolts on these older engines can be re-used, unlike most of the newer engines that have torque to yield bolts. I hope you have a book there to help you put it back together if you never have done this before.
Old Apr 4, 2025 | 06:00 PM
packagerjr's Avatar
packagerjr
They’re hard to find, but the Tom Monroe book on 335 and 385 series engines is good. Used it for my 460 build. I have an OEM manual as well but the book is laid out in a nice chronological order with the right info.
Old Apr 6, 2025 | 11:21 AM
Nathan ozias
yes I have the oem manual that I am using as well as several videos
Old Apr 7, 2025 | 12:42 PM
GOVTMOD's Avatar
GOVTMOD
You might want to go over to the Engine forum for the 335 Block engines.
I asked a similar question as I have a wiped cam lobe. Turns out you can use a 351 C cam for a 4 barrel, it's not extreme but gets you a little more lift. Its not listed as an option by any parts supplier for the 351M. I already have a 4 bbl edelbrock carb and intake as well.
